I have a problem with capturing DOL HDR mode with argus_camera app. I was going through reference sensor (and manual) that implemented DOL HDR, imx274.
Sensor that I tried is imx335, and image drawing of DOL 2 frame is next:
Vertical:
5 blanking
1 FS
1 EBD (Embedded line)
3 Ignored_OB_1
3 Ignored_OB_2
13 Vertical Effective OB
4 Ignored area of effective pixel side
8 Effective margin for collor proc
1944 Active
8 Effective
Horizontal:
PH, 8 LI, 12 Effective margin, 2592 active, 12 Effective margin PH
VBP before = 5
VBP after = 6
Device tree settings:
mode0 { // 2616x1964
mclk_khz = "37125";
num_lanes = "4";
discontinuous_clk = "no";
cil_settletime = "0";
active_w = "2624"; (2616(Active + Margin) + 8(LI))
active_h = "3984"; (1964(Active + Margin) + 19(OB) + 4(Ignored) + 5(VBP))*2
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer_wdr_dol";
pixel_phase = "rggb";
readout_orientation = "0";
line_length = "4400";
inherent_gain = "1";
mclk_multiplier = "32";
pix_clk_hz = "1188000000";
min_gain_val = "1.0";
max_gain_val = "72.0";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.462526";
max_framerate = "60";
min_exp_time = "1";
max_exp_time = "65535";
embedded_metadata_height = "1";
num_of_exposure = "2";
num_of_ignored_lines = "23"; (OB + Ignored)
num_of_lines_offset_0 = "5"; (VBP before)
num_of_ignored_pixels = "8"; (LI)
num_of_left_margin_pixels = "0";
num_of_right_margin_pixels = "0";
Error code from trace log is next:
# tracer: nop
# entries-in-buffer/entries-written: 643/643 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:4-1948 [001] .... 55.555770: rtos_queue_peek_from_isr_failed: tstamp:2013921395 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 55.725543: rtos_queue_peek_from_isr_failed: tstamp:2018921396 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 55.895320: rtos_queue_peek_from_isr_failed: tstamp:2023921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.065000: rtos_queue_peek_from_isr_failed: tstamp:2028921412 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.177962: rtos_queue_peek_from_isr_failed: tstamp:2033921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.347577: rtos_queue_peek_from_isr_failed: tstamp:2038921403 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.517233: rtos_queue_peek_from_isr_failed: tstamp:2043921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.686833: rtos_queue_peek_from_isr_failed: tstamp:2048921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 56.856327: rtos_queue_peek_from_isr_failed: tstamp:2053921391 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.025788: rtos_queue_peek_from_isr_failed: tstamp:2058921361 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.138717: rtos_queue_peek_from_isr_failed: tstamp:2063921400 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.308046: rtos_queue_peek_from_isr_failed: tstamp:2068921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.477440: rtos_queue_peek_from_isr_failed: tstamp:2073921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.646787: rtos_queue_peek_from_isr_failed: tstamp:2078921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.816156: rtos_queue_peek_from_isr_failed: tstamp:2083921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 57.985441: rtos_queue_peek_from_isr_failed: tstamp:2088921396 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.098238: rtos_queue_peek_from_isr_failed: tstamp:2093921452 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.267471: rtos_queue_peek_from_isr_failed: tstamp:2098921378 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.436711: rtos_queue_peek_from_isr_failed: tstamp:2103921395 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.605919: rtos_queue_peek_from_isr_failed: tstamp:2108921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.775069: rtos_queue_peek_from_isr_failed: tstamp:2113921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 58.944251: rtos_queue_peek_from_isr_failed: tstamp:2118921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.056944: rtos_queue_peek_from_isr_failed: tstamp:2123921409 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.226058: rtos_queue_peek_from_isr_failed: tstamp:2128921391 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.395138: rtos_queue_peek_from_isr_failed: tstamp:2133921391 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.564156: rtos_queue_peek_from_isr_failed: tstamp:2138921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.733265: rtos_queue_peek_from_isr_failed: tstamp:2143921399 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 59.902271: rtos_queue_peek_from_isr_failed: tstamp:2148921400 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.071281: rtos_queue_peek_from_isr_failed: tstamp:2153921391 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.183800: rtos_queue_send_from_isr_failed: tstamp:2158781060 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 60.183808: rtos_queue_send_from_isr_failed: tstamp:2158781278 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 60.183810: rtos_queue_send_from_isr_failed: tstamp:2158781490 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 60.183811: rtos_queue_send_from_isr_failed: tstamp:2158781698 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 60.183812: rtos_queue_send_from_isr_failed: tstamp:2158781907 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 60.183816: rtcpu_string: tstamp:2158788664 id:0x04010000 str:"Total number of isp channels : 16
kworker/1:4-1948 [001] .... 60.183843: rtos_queue_peek_from_isr_failed: tstamp:2158921396 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.352772: rtos_queue_peek_from_isr_failed: tstamp:2163921412 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.521651: rtos_queue_peek_from_isr_failed: tstamp:2168921397 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.694659: rtos_queue_peek_from_isr_failed: tstamp:2173921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 60.807263: rtos_queue_send_from_isr_failed: tstamp:2177196483 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 60.807273: rtos_queue_send_from_isr_failed: tstamp:2177196702 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 60.807274: rtos_queue_send_from_isr_failed: tstamp:2177196915 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 60.807279: rtos_queue_send_from_isr_failed: tstamp:2177197129 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 60.807281: rtos_queue_send_from_isr_failed: tstamp:2177197335 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 60.807284: rtcpu_string: tstamp:2177205472 id:0x04010000 str:"vi5_hwinit: firmware CL2018061801 protocol versi"
kworker/1:4-1948 [001] .... 60.807290: rtcpu_string: tstamp:2177205699 id:0x04010000 str:"on 2.2
kworker/1:4-1948 [001] .... 60.807320: rtos_queue_send_from_isr_failed: tstamp:2177223961 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 60.807321: rtos_queue_send_from_isr_failed: tstamp:2177224210 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 60.807322: rtos_queue_send_from_isr_failed: tstamp:2177224421 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 60.807323: rtos_queue_send_from_isr_failed: tstamp:2177224630 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 60.807324: rtos_queue_send_from_isr_failed: tstamp:2177224836 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 60.863516: rtos_queue_peek_from_isr_failed: tstamp:2178921413 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.032382: rtos_queue_peek_from_isr_failed: tstamp:2183921401 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.145008: rtos_queue_peek_from_isr_failed: tstamp:2188921394 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.313734: rtos_queue_peek_from_isr_failed: tstamp:2193921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.482523: rtos_queue_peek_from_isr_failed: tstamp:2198921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.651350: rtos_queue_peek_from_isr_failed: tstamp:2203921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.820277: rtos_queue_peek_from_isr_failed: tstamp:2208921392 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 61.876509: rtos_queue_send_from_isr_failed: tstamp:2211056304 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.876667: rtos_queue_send_from_isr_failed: tstamp:2211056518 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.876670: rtos_queue_send_from_isr_failed: tstamp:2211056739 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.876671: rtos_queue_send_from_isr_failed: tstamp:2211056955 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.876672: rtos_queue_send_from_isr_failed: tstamp:2211057163 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.876674: rtos_queue_send_from_isr_failed: tstamp:2211067366 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.876675: rtos_queue_send_from_isr_failed: tstamp:2211067574 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.876676: rtos_queue_send_from_isr_failed: tstamp:2211067786 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.876677: rtos_queue_send_from_isr_failed: tstamp:2211067995 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.876678: rtos_queue_send_from_isr_failed: tstamp:2211068202 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.876679: rtos_queue_send_from_isr_failed: tstamp:2211073664 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.876680: rtos_queue_send_from_isr_failed: tstamp:2211073873 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.876681: rtos_queue_send_from_isr_failed: tstamp:2211074084 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.876683: rtos_queue_send_from_isr_failed: tstamp:2211074293 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.876684: rtos_queue_send_from_isr_failed: tstamp:2211074500 queue:0x0bcc80d8
kworker/1:4-1948 [001] .n.. 61.933669: rtos_queue_send_from_isr_failed: tstamp:2212247107 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.933739: rtos_queue_send_from_isr_failed: tstamp:2212247323 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.933741: rtos_queue_send_from_isr_failed: tstamp:2212247535 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.933742: rtos_queue_send_from_isr_failed: tstamp:2212247742 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.933743: rtos_queue_send_from_isr_failed: tstamp:2212247957 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.933745: rtos_queue_send_from_isr_failed: tstamp:2212256543 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.933746: rtos_queue_send_from_isr_failed: tstamp:2212256753 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.933747: rtos_queue_send_from_isr_failed: tstamp:2212256964 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.933780: rtos_queue_send_from_isr_failed: tstamp:2212257172 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.933781: rtos_queue_send_from_isr_failed: tstamp:2212257379 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.933783: rtos_queue_send_from_isr_failed: tstamp:2212325294 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.933785: rtos_queue_send_from_isr_failed: tstamp:2212325501 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.933787: rtos_queue_send_from_isr_failed: tstamp:2212325713 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.933788: rtos_queue_send_from_isr_failed: tstamp:2212325919 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.933789: rtos_queue_send_from_isr_failed: tstamp:2212326125 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.933790: rtos_queue_send_from_isr_failed: tstamp:2212344005 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 61.933791: rtos_queue_send_from_isr_failed: tstamp:2212344215 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 61.933792: rtos_queue_send_from_isr_failed: tstamp:2212344433 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 61.933793: rtos_queue_send_from_isr_failed: tstamp:2212344639 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 61.933795: rtos_queue_send_from_isr_failed: tstamp:2212344845 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 61.988883: rtos_queue_peek_from_isr_failed: tstamp:2213921396 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.101351: rtos_queue_peek_from_isr_failed: tstamp:2218921365 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.161676: rtos_queue_send_from_isr_failed: tstamp:2219163367 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.161682: rtos_queue_send_from_isr_failed: tstamp:2219163518 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.161684: rtos_queue_send_from_isr_failed: tstamp:2219163669 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.161685: rtos_queue_send_from_isr_failed: tstamp:2219163816 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.161686: rtos_queue_send_from_isr_failed: tstamp:2219163961 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.161689: rtcpu_vinotify_event: tstamp:2219201146 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2293843104 data:0x10000000
kworker/1:4-1948 [001] .... 62.161690: rtcpu_vinotify_event: tstamp:2219201296 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2293880896 data:0x31000001
kworker/1:4-1948 [001] .... 62.161691: rtcpu_vinotify_event: tstamp:2219201469 tag:RESERVED_19 channel:0x0b frame:0 vi_tstamp:2293886528 data:0x07020001
kworker/1:4-1948 [001] .... 62.161692: rtcpu_vinotify_event: tstamp:2219201611 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2293901824 data:0x10000000
kworker/1:4-1948 [001] .... 62.161694: rtcpu_vinotify_event: tstamp:2219201777 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2293923008 data:0x31000001
kworker/1:4-1948 [001] .... 62.161695: rtcpu_vinotify_event: tstamp:2219201917 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2293928544 data:0x07020001
kworker/1:4-1948 [001] .... 62.161696: rtos_queue_send_from_isr_failed: tstamp:2219684730 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.161698: rtos_queue_send_from_isr_failed: tstamp:2219684879 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.161699: rtos_queue_send_from_isr_failed: tstamp:2219685028 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.161700: rtos_queue_send_from_isr_failed: tstamp:2219685175 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.161701: rtos_queue_send_from_isr_failed: tstamp:2219685321 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.161702: rtcpu_vinotify_event: tstamp:2219703971 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2310528832 data:0x10000000
kworker/1:4-1948 [001] .... 62.161703: rtcpu_vinotify_event: tstamp:2219704123 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2310572128 data:0x31000002
kworker/1:4-1948 [001] .... 62.161736: rtcpu_vinotify_event: tstamp:2219704293 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2310590304 data:0x10000000
kworker/1:4-1948 [001] .... 62.161738: rtcpu_vinotify_event: tstamp:2219704436 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2310611712 data:0x31000002
kworker/1:4-1948 [001] .... 62.161739: rtcpu_vinotify_event: tstamp:2219704603 tag:FS channel:0x00 frame:1 vi_tstamp:2219700806 data:0x00000010
kworker/1:4-1948 [001] .... 62.161740: rtcpu_vinotify_event: tstamp:2219704742 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:2219700808 data:0x00000800
kworker/1:4-1948 [001] .... 62.161741: rtcpu_vinotify_event: tstamp:2219704908 tag:CHANSEL_EMBED_SOF channel:0x0b frame:1 vi_tstamp:2219701585 data:0x00000004
kworker/1:4-1948 [001] .... 62.161742: rtcpu_vinotify_event: tstamp:2219705048 tag:CHANSEL_EMBED_EOF channel:0x0b frame:1 vi_tstamp:2219701851 data:0x00000008
kworker/1:4-1948 [001] .... 62.161743: rtcpu_vinotify_event: tstamp:2219705214 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:1 vi_tstamp:2219701874 data:0x00000000
kworker/1:4-1948 [001] .... 62.161744: rtcpu_vinotify_event: tstamp:2219705355 tag:RESERVED_19 channel:0x0b frame:1 vi_tstamp:2310987488 data:0x03020001
kworker/1:4-1948 [001] .... 62.161745: rtos_queue_send_from_isr_failed: tstamp:2219712261 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.161748: rtos_queue_send_from_isr_failed: tstamp:2219712414 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.161749: rtos_queue_send_from_isr_failed: tstamp:2219712565 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.161750: rtos_queue_send_from_isr_failed: tstamp:2219712712 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.161751: rtos_queue_send_from_isr_failed: tstamp:2219712860 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.161761: rtcpu_vinotify_event: tstamp:2220038505 tag:CHANSEL_FAULT channel:0x0b frame:1 vi_tstamp:2219706240 data:0x00010800
kworker/1:4-1948 [001] .... 62.161762: rtcpu_vinotify_event: tstamp:2220038656 tag:RESERVED_19 channel:0x0b frame:1 vi_tstamp:2311127968 data:0x01020001
kworker/1:4-1948 [001] .... 62.161763: rtcpu_vinotify_event: tstamp:2220038826 tag:CHANSEL_FAULT channel:0x0b frame:1 vi_tstamp:2219731661 data:0x00170801
kworker/1:4-1948 [001] .... 62.161764: rtcpu_vinotify_event: tstamp:2220038970 tag:RESERVED_19 channel:0x0b frame:1 vi_tstamp:2311941472 data:0x01020001
kworker/1:4-1948 [001] .... 62.161766: rtcpu_vinotify_event: tstamp:2220039137 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:2219732020 data:0x00170001
kworker/1:4-1948 [001] .... 62.161767: rtcpu_vinotify_event: tstamp:2220039276 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:2311950624 data:0x08020001
kworker/1:4-1948 [001] .... 62.161768: rtcpu_vinotify_event: tstamp:2220510386 tag:FE channel:0x00 frame:1 vi_tstamp:2220506418 data:0x00000020
kworker/1:4-1948 [001] .... 62.161769: rtcpu_vinotify_event: tstamp:2220510535 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:2220506419 data:0x01000800
kworker/1:4-1948 [001] .... 62.161770: rtcpu_vinotify_event: tstamp:2220510708 tag:RESERVED_19 channel:0x0b frame:1 vi_tstamp:2336736736 data:0x01020001
kworker/1:4-1948 [001] .... 62.161771: rtcpu_vinotify_event: tstamp:2220510853 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:2336744512 data:0x01020001
kworker/1:4-1948 [001] .... 62.161772: rtcpu_vinotify_event: tstamp:2220511019 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:2220506420 data:0x00000800
kworker/1:4-1948 [001] .... 62.161773: rtcpu_vinotify_event: tstamp:2220511163 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2336765984 data:0x07020002
kworker/1:4-1948 [001] .... 62.161774: rtcpu_vinotify_event: tstamp:2220511326 tag:FS channel:0x00 frame:2 vi_tstamp:2220506439 data:0x00000010
kworker/1:4-1948 [001] .... 62.161776: rtcpu_vinotify_event: tstamp:2220511466 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:2220506441 data:0x00000800
kworker/1:4-1948 [001] .... 62.161777: rtcpu_vinotify_event: tstamp:2220511632 tag:CHANSEL_EMBED_SOF channel:0x0b frame:2 vi_tstamp:2220507199 data:0x00000004
kworker/1:4-1948 [001] .... 62.161778: rtcpu_vinotify_event: tstamp:2220511772 tag:CHANSEL_EMBED_EOF channel:0x0b frame:2 vi_tstamp:2220507464 data:0x00000008
kworker/1:4-1948 [001] .... 62.161780: rtos_queue_send_from_isr_failed: tstamp:2220584341 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.161781: rtos_queue_send_from_isr_failed: tstamp:2220584493 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.161782: rtos_queue_send_from_isr_failed: tstamp:2220584644 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.161783: rtos_queue_send_from_isr_failed: tstamp:2220584792 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.161785: rtos_queue_send_from_isr_failed: tstamp:2220584937 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.161786: rtos_queue_send_from_isr_failed: tstamp:2220585736 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.161787: rtos_queue_send_from_isr_failed: tstamp:2220585893 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.161788: rtos_queue_send_from_isr_failed: tstamp:2220586032 queue:0x0bcc64f0
kworker/1:4-1948 [001] .... 62.161789: rtos_queue_send_from_isr_failed: tstamp:2220586168 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.161790: rtos_queue_send_from_isr_failed: tstamp:2220586304 queue:0x0bcc72b0
kworker/1:4-1948 [001] .... 62.161792: rtos_queue_send_from_isr_failed: tstamp:2220586440 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.161793: rtos_queue_send_from_isr_failed: tstamp:2220586575 queue:0x0bcc8070
kworker/1:4-1948 [001] .... 62.161794: rtos_queue_send_from_isr_failed: tstamp:2220586710 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.161795: rtcpu_vinotify_event: tstamp:2220840730 tag:ATOMP_EMB_DATA_DONE channel:0x0b frame:2 vi_tstamp:2220507487 data:0x00000000
kworker/1:4-1948 [001] .... 62.161796: rtcpu_vinotify_event: tstamp:2220840902 tag:RESERVED_19 channel:0x0b frame:2 vi_tstamp:2336787712 data:0x03020001
kworker/1:4-1948 [001] .... 62.161797: rtcpu_vinotify_event: tstamp:2220841072 tag:CHANSEL_FAULT channel:0x0b frame:2 vi_tstamp:2220511853 data:0x00010800
kworker/1:4-1948 [001] .... 62.161798: rtcpu_vinotify_event: tstamp:2220841216 tag:RESERVED_19 channel:0x0b frame:2 vi_tstamp:2336907616 data:0x01020001
kworker/1:4-1948 [001] .... 62.161800: rtcpu_vinotify_event: tstamp:2220841383 tag:CHANSEL_FAULT channel:0x0b frame:2 vi_tstamp:2220537275 data:0x00170801
kworker/1:4-1948 [001] .... 62.161801: rtcpu_vinotify_event: tstamp:2220841523 tag:RESERVED_19 channel:0x0b frame:2 vi_tstamp:2337721088 data:0x01020001
kworker/1:4-1948 [001] .... 62.161802: rtcpu_vinotify_event: tstamp:2220841688 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:2220537632 data:0x00170001
kworker/1:4-1948 [001] .... 62.161803: rtcpu_vinotify_event: tstamp:2220841828 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:2337730240 data:0x08020002
kworker/1:4-1948 [001] .... 62.161804: rtcpu_vinotify_event: tstamp:2220841994 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2337863584 data:0x10000000
kworker/1:4-1948 [001] .... 62.161805: rtcpu_vinotify_event: tstamp:2220842134 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2337885376 data:0x31000003
kworker/1:4-1948 [001] .... 62.217861: rtcpu_vinotify_error: tstamp:2221316768 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:2221312095 data:0x00000569
kworker/1:4-1948 [001] .... 62.217868: rtcpu_vinotify_event: tstamp:2221317243 tag:FE channel:0x00 frame:2 vi_tstamp:2221312032 data:0x00000020
kworker/1:4-1948 [001] .... 62.217869: rtcpu_vinotify_event: tstamp:2221317388 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:2221312032 data:0x01000800
kworker/1:4-1948 [001] .... 62.217870: rtcpu_vinotify_event: tstamp:2221317559 tag:RESERVED_19 channel:0x0b frame:2 vi_tstamp:2362516352 data:0x01020001
kworker/1:4-1948 [001] .... 62.217871: rtcpu_vinotify_event: tstamp:2221317705 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:2362524096 data:0x01020002
kworker/1:4-1948 [001] .... 62.217872: rtcpu_vinotify_event: tstamp:2221317873 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:2221312033 data:0x00000800
kworker/1:4-1948 [001] .... 62.217874: rtcpu_vinotify_event: tstamp:2221318013 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2362545600 data:0x07020003
kworker/1:4-1948 [001] .... 62.217877: rtos_queue_send_from_isr_failed: tstamp:2221556626 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.217878: rtos_queue_send_from_isr_failed: tstamp:2221556776 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.217880: rtos_queue_send_from_isr_failed: tstamp:2221556927 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.217881: rtos_queue_send_from_isr_failed: tstamp:2221557076 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.217882: rtos_queue_send_from_isr_failed: tstamp:2221557222 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.217883: rtos_queue_send_from_isr_failed: tstamp:2221558117 queue:0x0bcc10a0
kworker/1:4-1948 [001] .... 62.217884: rtos_queue_send_from_isr_failed: tstamp:2221558269 queue:0x0bcc49d8
kworker/1:4-1948 [001] .... 62.217885: rtos_queue_send_from_isr_failed: tstamp:2221558414 queue:0x0bcc6558
kworker/1:4-1948 [001] .... 62.217886: rtos_queue_send_from_isr_failed: tstamp:2221558550 queue:0x0bcc72b0
kworker/1:4-1948 [001] .... 62.217887: rtos_queue_send_from_isr_failed: tstamp:2221558684 queue:0x0bcc7318
kworker/1:4-1948 [001] .... 62.217888: rtos_queue_send_from_isr_failed: tstamp:2221558821 queue:0x0bcc8070
kworker/1:4-1948 [001] .... 62.217890: rtos_queue_send_from_isr_failed: tstamp:2221558955 queue:0x0bcc80d8
kworker/1:4-1948 [001] .... 62.217891: rtcpu_vinotify_event: tstamp:2221642872 tag:FS channel:0x00 frame:3 vi_tstamp:2221312052 data:0x00000010
kworker/1:4-1948 [001] .... 62.217892: rtcpu_vinotify_event: tstamp:2221643021 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:2221312054 data:0x00000000
kworker/1:4-1948 [001] .... 62.217893: rtcpu_vinotify_event: tstamp:2221643188 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:2221312095 data:0x00000569
kworker/1:4-1948 [001] .... 62.217894: rtcpu_vinotify_event: tstamp:2221643333 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:2221312811 data:0x00004004
kworker/1:4-1948 [001] .... 62.217895: rtcpu_vinotify_event: tstamp:2221643499 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:2362569344 data:0x01020003
kworker/1:4-1948 [001] .... 62.217896: rtcpu_vinotify_event: tstamp:2221643638 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:2221343246 data:0x00174001
kworker/1:4-1948 [001] .... 62.217897: rtcpu_vinotify_event: tstamp:2221643808 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:2363512160 data:0x01020003
kworker/1:4-1948 [001] .... 62.217899: rtcpu_vinotify_error: tstamp:2222120555 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:2222117708 data:0x00000569
kworker/1:4-1948 [001] .... 62.217900: rtcpu_vinotify_event: tstamp:2222340286 tag:FE channel:0x00 frame:3 vi_tstamp:2222117645 data:0x00000020
kworker/1:4-1948 [001] .... 62.217901: rtcpu_vinotify_event: tstamp:2222340452 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:2222117645 data:0x00000000
kworker/1:4-1948 [001] .... 62.217902: rtcpu_vinotify_event: tstamp:2222340600 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:2388300032 data:0x01020003
kworker/1:4-1948 [001] .... 62.217903: rtcpu_vinotify_event: tstamp:2222340762 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:2222117645 data:0x01000000
kworker/1:4-1948 [001] .... 62.217904: rtcpu_vinotify_event: tstamp:2222340907 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:2388310784 data:0x01020003
kworker/1:4-1948 [001] .... 62.217905: rtcpu_vinotify_event: tstamp:2222341072 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:2222117646 data:0x00000000
kworker/1:4-1948 [001] .... 62.217906: rtcpu_vinotify_event: tstamp:2222341212 tag:FS channel:0x00 frame:4 vi_tstamp:2222117665 data:0x00000010
kworker/1:4-1948 [001] .... 62.217908: rtcpu_vinotify_event: tstamp:2222341374 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:2222117708 data:0x00000569
kworker/1:4-1948 [001] .... 62.274067: rtcpu_vinotify_error: tstamp:2222925352 tag:CHANSEL_NOMATCH channel:0x01 frame:5 vi_tstamp:2222923321 data:0x00000569
kworker/1:4-1948 [001] .... 62.274075: rtcpu_vinotify_event: tstamp:2222925695 tag:FE channel:0x00 frame:4 vi_tstamp:2222923257 data:0x00000020
kworker/1:4-1948 [001] .... 62.274076: rtcpu_vinotify_event: tstamp:2223247017 tag:FS channel:0x00 frame:5 vi_tstamp:2222923278 data:0x00000010
kworker/1:4-1948 [001] .... 62.274077: rtcpu_vinotify_event: tstamp:2223247159 tag:CHANSEL_NOMATCH channel:0x01 frame:5 vi_tstamp:2222923321 data:0x00000569
kworker/1:4-1948 [001] .... 62.274078: rtcpu_vinotify_error: tstamp:2223730831 tag:CHANSEL_NOMATCH channel:0x01 frame:6 vi_tstamp:2223728934 data:0x00000569
kworker/1:4-1948 [001] .... 62.274083: rtos_queue_peek_from_isr_failed: tstamp:2223921365 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.274084: rtcpu_vinotify_event: tstamp:2223944542 tag:FE channel:0x00 frame:5 vi_tstamp:2223728870 data:0x00000020
kworker/1:4-1948 [001] .... 62.274085: rtcpu_vinotify_event: tstamp:2223944686 tag:FS channel:0x00 frame:6 vi_tstamp:2223728891 data:0x00000010
kworker/1:4-1948 [001] .... 62.274086: rtcpu_vinotify_event: tstamp:2223944853 tag:CHANSEL_NOMATCH channel:0x01 frame:6 vi_tstamp:2223728934 data:0x00000569
kworker/1:4-1948 [001] .... 62.330306: rtcpu_vinotify_error: tstamp:2224536522 tag:CHANSEL_NOMATCH channel:0x01 frame:7 vi_tstamp:2224534547 data:0x00000569
kworker/1:4-1948 [001] .... 62.330313: rtcpu_vinotify_event: tstamp:2224642060 tag:FE channel:0x00 frame:6 vi_tstamp:2224534483 data:0x00000020
kworker/1:4-1948 [001] .... 62.330315: rtcpu_vinotify_event: tstamp:2224642226 tag:FS channel:0x00 frame:7 vi_tstamp:2224534504 data:0x00000010
kworker/1:4-1948 [001] .... 62.330316: rtcpu_vinotify_event: tstamp:2224642370 tag:CHANSEL_NOMATCH channel:0x01 frame:7 vi_tstamp:2224534547 data:0x00000569
kworker/1:4-1948 [001] .... 62.330318: rtcpu_vinotify_error: tstamp:2225342047 tag:CHANSEL_NOMATCH channel:0x01 frame:8 vi_tstamp:2225340160 data:0x00000569
kworker/1:4-1948 [001] .... 62.330319: rtcpu_vinotify_event: tstamp:2225688319 tag:FE channel:0x00 frame:7 vi_tstamp:2225340096 data:0x00000020
kworker/1:4-1948 [001] .... 62.330321: rtcpu_vinotify_event: tstamp:2225688463 tag:FS channel:0x00 frame:8 vi_tstamp:2225340117 data:0x00000010
kworker/1:4-1948 [001] .... 62.330357: rtcpu_vinotify_event: tstamp:2225688632 tag:CHANSEL_NOMATCH channel:0x01 frame:8 vi_tstamp:2225340160 data:0x00000569
kworker/1:4-1948 [001] .... 62.330358: rtcpu_vinotify_error: tstamp:2226147672 tag:CHANSEL_NOMATCH channel:0x01 frame:9 vi_tstamp:2226145773 data:0x00000569
kworker/1:4-1948 [001] .... 62.386559: rtcpu_vinotify_event: tstamp:2226385839 tag:FE channel:0x00 frame:8 vi_tstamp:2226145708 data:0x00000020
kworker/1:4-1948 [001] .... 62.386565: rtcpu_vinotify_event: tstamp:2226386007 tag:FS channel:0x00 frame:9 vi_tstamp:2226145730 data:0x00000010
kworker/1:4-1948 [001] .... 62.386566: rtcpu_vinotify_event: tstamp:2226386151 tag:CHANSEL_NOMATCH channel:0x01 frame:9 vi_tstamp:2226145773 data:0x00000569
kworker/1:4-1948 [001] .... 62.386568: rtcpu_vinotify_error: tstamp:2226953407 tag:CHANSEL_NOMATCH channel:0x01 frame:10 vi_tstamp:2226951386 data:0x00000569
kworker/1:4-1948 [001] .... 62.386570: rtcpu_vinotify_event: tstamp:2226953785 tag:FE channel:0x00 frame:9 vi_tstamp:2226951321 data:0x00000020
kworker/1:4-1948 [001] .... 62.386571: rtcpu_vinotify_event: tstamp:2226953929 tag:FS channel:0x00 frame:10 vi_tstamp:2226951342 data:0x00000010
kworker/1:4-1948 [001] .... 62.386572: rtcpu_vinotify_event: tstamp:2227292587 tag:CHANSEL_NOMATCH channel:0x01 frame:10 vi_tstamp:2226951386 data:0x00000569
kworker/1:4-1948 [001] .... 62.386574: rtcpu_vinotify_error: tstamp:2227758896 tag:CHANSEL_NOMATCH channel:0x01 frame:11 vi_tstamp:2227756998 data:0x00000569
kworker/1:4-1948 [001] .... 62.442821: rtcpu_vinotify_event: tstamp:2227990609 tag:FE channel:0x00 frame:10 vi_tstamp:2227756934 data:0x00000020
kworker/1:4-1948 [001] .... 62.442827: rtcpu_vinotify_event: tstamp:2227990776 tag:FS channel:0x00 frame:11 vi_tstamp:2227756955 data:0x00000010
kworker/1:4-1948 [001] .... 62.442829: rtcpu_vinotify_event: tstamp:2227990919 tag:CHANSEL_NOMATCH channel:0x01 frame:11 vi_tstamp:2227756998 data:0x00000569
kworker/1:4-1948 [001] .... 62.442831: rtcpu_vinotify_error: tstamp:2228564507 tag:CHANSEL_NOMATCH channel:0x01 frame:12 vi_tstamp:2228562611 data:0x00000569
kworker/1:4-1948 [001] .... 62.442832: rtcpu_vinotify_event: tstamp:2228688135 tag:FE channel:0x00 frame:11 vi_tstamp:2228562548 data:0x00000020
kworker/1:4-1948 [001] .... 62.442833: rtcpu_vinotify_event: tstamp:2228688276 tag:FS channel:0x00 frame:12 vi_tstamp:2228562568 data:0x00000010
kworker/1:4-1948 [001] .... 62.442834: rtcpu_vinotify_event: tstamp:2228688446 tag:CHANSEL_NOMATCH channel:0x01 frame:12 vi_tstamp:2228562611 data:0x00000569
kworker/1:4-1948 [001] .... 62.442837: rtos_queue_peek_from_isr_failed: tstamp:2228921366 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.442866: rtcpu_vinotify_error: tstamp:2229370140 tag:CHANSEL_NOMATCH channel:0x01 frame:13 vi_tstamp:2229368224 data:0x00000569
kworker/1:4-1948 [001] .... 62.442867: rtcpu_vinotify_event: tstamp:2229385680 tag:FE channel:0x00 frame:12 vi_tstamp:2229368160 data:0x00000020
kworker/1:4-1948 [001] .... 62.442868: rtcpu_vinotify_event: tstamp:2229385848 tag:FS channel:0x00 frame:13 vi_tstamp:2229368181 data:0x00000010
kworker/1:4-1948 [001] .... 62.442869: rtcpu_vinotify_event: tstamp:2229385992 tag:CHANSEL_NOMATCH channel:0x01 frame:13 vi_tstamp:2229368224 data:0x00000569
kworker/1:4-1948 [001] .... 62.499013: rtcpu_vinotify_error: tstamp:2230175735 tag:CHANSEL_NOMATCH channel:0x01 frame:14 vi_tstamp:2230173837 data:0x00000569
kworker/1:4-1948 [001] .... 62.499056: rtcpu_vinotify_event: tstamp:2230431929 tag:FE channel:0x00 frame:13 vi_tstamp:2230173773 data:0x00000020
kworker/1:4-1948 [001] .... 62.499057: rtcpu_vinotify_event: tstamp:2230432091 tag:FS channel:0x00 frame:14 vi_tstamp:2230173794 data:0x00000010
kworker/1:4-1948 [001] .... 62.499059: rtcpu_vinotify_event: tstamp:2230432258 tag:CHANSEL_NOMATCH channel:0x01 frame:14 vi_tstamp:2230173837 data:0x00000569
kworker/1:4-1948 [001] .... 62.499060: rtcpu_vinotify_error: tstamp:2230981479 tag:CHANSEL_NOMATCH channel:0x01 frame:15 vi_tstamp:2230979450 data:0x00000569
kworker/1:4-1948 [001] .... 62.499061: rtcpu_vinotify_event: tstamp:2230981816 tag:FE channel:0x00 frame:14 vi_tstamp:2230979386 data:0x00000020
kworker/1:4-1948 [001] .... 62.499062: rtcpu_vinotify_event: tstamp:2230981985 tag:FS channel:0x00 frame:15 vi_tstamp:2230979406 data:0x00000010
kworker/1:4-1948 [001] .... 62.499064: rtcpu_vinotify_event: tstamp:2230982125 tag:CHANSEL_NOMATCH channel:0x01 frame:15 vi_tstamp:2230979450 data:0x00000569
kworker/1:4-1948 [001] .... 62.555270: rtcpu_vinotify_error: tstamp:2231786964 tag:CHANSEL_NOMATCH channel:0x01 frame:16 vi_tstamp:2231785062 data:0x00000569
kworker/1:4-1948 [001] .... 62.555276: rtcpu_vinotify_event: tstamp:2231791930 tag:FE channel:0x00 frame:15 vi_tstamp:2231784999 data:0x00000020
kworker/1:4-1948 [001] .... 62.555278: rtcpu_vinotify_event: tstamp:2231792074 tag:FS channel:0x00 frame:16 vi_tstamp:2231785019 data:0x00000010
kworker/1:4-1948 [001] .... 62.555315: rtcpu_vinotify_event: tstamp:2231792240 tag:CHANSEL_NOMATCH channel:0x01 frame:16 vi_tstamp:2231785062 data:0x00000569
kworker/1:4-1948 [001] .... 62.555316: rtcpu_vinotify_error: tstamp:2232592585 tag:CHANSEL_NOMATCH channel:0x01 frame:17 vi_tstamp:2232590675 data:0x00000569
kworker/1:4-1948 [001] .... 62.555317: rtcpu_vinotify_event: tstamp:2232838187 tag:FE channel:0x00 frame:16 vi_tstamp:2232590612 data:0x00000020
kworker/1:4-1948 [001] .... 62.555319: rtcpu_vinotify_event: tstamp:2232838354 tag:FS channel:0x00 frame:17 vi_tstamp:2232590633 data:0x00000010
kworker/1:4-1948 [001] .... 62.555320: rtcpu_vinotify_event: tstamp:2232838497 tag:CHANSEL_NOMATCH channel:0x01 frame:17 vi_tstamp:2232590675 data:0x00000569
kworker/1:4-1948 [001] .... 62.611510: rtcpu_vinotify_error: tstamp:2233398192 tag:CHANSEL_NOMATCH channel:0x01 frame:18 vi_tstamp:2233396289 data:0x00000569
kworker/1:4-1948 [001] .... 62.611517: rtcpu_vinotify_event: tstamp:2233535753 tag:FE channel:0x00 frame:17 vi_tstamp:2233396224 data:0x00000020
kworker/1:4-1948 [001] .... 62.611518: rtcpu_vinotify_event: tstamp:2233535897 tag:FS channel:0x00 frame:18 vi_tstamp:2233396246 data:0x00000010
kworker/1:4-1948 [001] .... 62.611519: rtcpu_vinotify_event: tstamp:2233536068 tag:CHANSEL_NOMATCH channel:0x01 frame:18 vi_tstamp:2233396289 data:0x00000569
kworker/1:4-1948 [001] .... 62.611559: rtos_queue_peek_from_isr_failed: tstamp:2233921365 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.611562: rtcpu_vinotify_error: tstamp:2234203802 tag:CHANSEL_NOMATCH channel:0x01 frame:19 vi_tstamp:2234201902 data:0x00000569
kworker/1:4-1948 [001] .... 62.611563: rtcpu_vinotify_event: tstamp:2234233236 tag:FE channel:0x00 frame:18 vi_tstamp:2234201837 data:0x00000020
kworker/1:4-1948 [001] .... 62.611564: rtcpu_vinotify_event: tstamp:2234233402 tag:FS channel:0x00 frame:19 vi_tstamp:2234201858 data:0x00000010
kworker/1:4-1948 [001] .... 62.611565: rtcpu_vinotify_event: tstamp:2234233546 tag:CHANSEL_NOMATCH channel:0x01 frame:19 vi_tstamp:2234201902 data:0x00000569
kworker/1:4-1948 [001] .... 62.667767: rtcpu_vinotify_error: tstamp:2235009412 tag:CHANSEL_NOMATCH channel:0x01 frame:20 vi_tstamp:2235007514 data:0x00000569
kworker/1:4-1948 [001] .... 62.667774: rtcpu_vinotify_event: tstamp:2235280023 tag:FE channel:0x00 frame:19 vi_tstamp:2235007450 data:0x00000020
kworker/1:4-1948 [001] .... 62.667775: rtcpu_vinotify_event: tstamp:2235280166 tag:FS channel:0x00 frame:20 vi_tstamp:2235007471 data:0x00000010
kworker/1:4-1948 [001] .... 62.667776: rtcpu_vinotify_event: tstamp:2235280334 tag:CHANSEL_NOMATCH channel:0x01 frame:20 vi_tstamp:2235007514 data:0x00000569
kworker/1:4-1948 [001] .... 62.667778: rtcpu_vinotify_error: tstamp:2235815170 tag:CHANSEL_NOMATCH channel:0x01 frame:21 vi_tstamp:2235813127 data:0x00000569
kworker/1:4-1948 [001] .... 62.667779: rtcpu_vinotify_event: tstamp:2235815525 tag:FE channel:0x00 frame:20 vi_tstamp:2235813064 data:0x00000020
kworker/1:4-1948 [001] .... 62.667780: rtcpu_vinotify_event: tstamp:2236151746 tag:FS channel:0x00 frame:21 vi_tstamp:2235813084 data:0x00000010
kworker/1:4-1948 [001] .... 62.667781: rtcpu_vinotify_event: tstamp:2236151886 tag:CHANSEL_NOMATCH channel:0x01 frame:21 vi_tstamp:2235813127 data:0x00000569
kworker/1:4-1948 [001] .... 62.667810: rtcpu_vinotify_error: tstamp:2236620658 tag:CHANSEL_NOMATCH channel:0x01 frame:22 vi_tstamp:2236618740 data:0x00000569
kworker/1:4-1948 [001] .... 62.723978: rtcpu_vinotify_event: tstamp:2236849277 tag:FE channel:0x00 frame:21 vi_tstamp:2236618676 data:0x00000020
kworker/1:4-1948 [001] .... 62.723983: rtcpu_vinotify_event: tstamp:2236849424 tag:FS channel:0x00 frame:22 vi_tstamp:2236618697 data:0x00000010
kworker/1:4-1948 [001] .... 62.723985: rtcpu_vinotify_event: tstamp:2236849590 tag:CHANSEL_NOMATCH channel:0x01 frame:22 vi_tstamp:2236618740 data:0x00000569
kworker/1:4-1948 [001] .... 62.723987: rtcpu_vinotify_error: tstamp:2237426269 tag:CHANSEL_NOMATCH channel:0x01 frame:23 vi_tstamp:2237424353 data:0x00000569
kworker/1:4-1948 [001] .... 62.723988: rtcpu_vinotify_event: tstamp:2237546799 tag:FE channel:0x00 frame:22 vi_tstamp:2237424289 data:0x00000020
kworker/1:4-1948 [001] .... 62.723990: rtcpu_vinotify_event: tstamp:2237546968 tag:FS channel:0x00 frame:23 vi_tstamp:2237424310 data:0x00000010
kworker/1:4-1948 [001] .... 62.723991: rtcpu_vinotify_event: tstamp:2237547109 tag:CHANSEL_NOMATCH channel:0x01 frame:23 vi_tstamp:2237424353 data:0x00000569
kworker/1:4-1948 [001] .... 62.723992: rtcpu_vinotify_error: tstamp:2238231864 tag:CHANSEL_NOMATCH channel:0x01 frame:24 vi_tstamp:2238229965 data:0x00000569
kworker/1:4-1948 [001] .... 62.724025: rtcpu_vinotify_event: tstamp:2238244320 tag:FE channel:0x00 frame:23 vi_tstamp:2238229902 data:0x00000020
kworker/1:4-1948 [001] .... 62.724026: rtcpu_vinotify_event: tstamp:2238244463 tag:FS channel:0x00 frame:24 vi_tstamp:2238229922 data:0x00000010
kworker/1:4-1948 [001] .... 62.724027: rtcpu_vinotify_event: tstamp:2238244628 tag:CHANSEL_NOMATCH channel:0x01 frame:24 vi_tstamp:2238229965 data:0x00000569
kworker/1:4-1948 [001] .... 62.780249: rtos_queue_peek_from_isr_failed: tstamp:2238921366 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.780255: rtcpu_vinotify_error: tstamp:2239037500 tag:CHANSEL_NOMATCH channel:0x01 frame:25 vi_tstamp:2239035578 data:0x00000569
kworker/1:4-1948 [001] .... 62.780258: rtcpu_vinotify_event: tstamp:2239290582 tag:FE channel:0x00 frame:24 vi_tstamp:2239035515 data:0x00000020
kworker/1:4-1948 [001] .... 62.780259: rtcpu_vinotify_event: tstamp:2239290749 tag:FS channel:0x00 frame:25 vi_tstamp:2239035536 data:0x00000010
kworker/1:4-1948 [001] .... 62.780289: rtcpu_vinotify_event: tstamp:2239290893 tag:CHANSEL_NOMATCH channel:0x01 frame:25 vi_tstamp:2239035578 data:0x00000569
kworker/1:4-1948 [001] .... 62.780291: rtcpu_vinotify_error: tstamp:2239843218 tag:CHANSEL_NOMATCH channel:0x01 frame:26 vi_tstamp:2239841191 data:0x00000569
kworker/1:4-1948 [001] .... 62.780292: rtcpu_vinotify_event: tstamp:2239843573 tag:FE channel:0x00 frame:25 vi_tstamp:2239841128 data:0x00000020
kworker/1:4-1948 [001] .... 62.780293: rtcpu_vinotify_event: tstamp:2239843716 tag:FS channel:0x00 frame:26 vi_tstamp:2239841149 data:0x00000010
kworker/1:4-1948 [001] .... 62.780294: rtcpu_vinotify_event: tstamp:2240162830 tag:CHANSEL_NOMATCH channel:0x01 frame:26 vi_tstamp:2239841191 data:0x00000569
kworker/1:4-1948 [001] .... 62.836441: rtcpu_vinotify_error: tstamp:2240648703 tag:CHANSEL_NOMATCH channel:0x01 frame:27 vi_tstamp:2240646804 data:0x00000569
kworker/1:4-1948 [001] .... 62.836446: rtcpu_vinotify_event: tstamp:2240860390 tag:FE channel:0x00 frame:26 vi_tstamp:2240646740 data:0x00000020
kworker/1:4-1948 [001] .... 62.836485: rtcpu_vinotify_event: tstamp:2240860556 tag:FS channel:0x00 frame:27 vi_tstamp:2240646762 data:0x00000010
kworker/1:4-1948 [001] .... 62.836487: rtcpu_vinotify_event: tstamp:2240860697 tag:CHANSEL_NOMATCH channel:0x01 frame:27 vi_tstamp:2240646804 data:0x00000569
kworker/1:4-1948 [001] .... 62.836488: rtcpu_vinotify_error: tstamp:2241454315 tag:CHANSEL_NOMATCH channel:0x01 frame:28 vi_tstamp:2241452417 data:0x00000569
kworker/1:4-1948 [001] .... 62.836490: rtcpu_vinotify_event: tstamp:2241557900 tag:FE channel:0x00 frame:27 vi_tstamp:2241452353 data:0x00000020
kworker/1:4-1948 [001] .... 62.836491: rtcpu_vinotify_event: tstamp:2241558043 tag:FS channel:0x00 frame:28 vi_tstamp:2241452374 data:0x00000010
kworker/1:4-1948 [001] .... 62.836492: rtcpu_vinotify_event: tstamp:2241558226 tag:CHANSEL_NOMATCH channel:0x01 frame:28 vi_tstamp:2241452417 data:0x00000569
kworker/1:4-1948 [001] .... 62.892785: rtcpu_vinotify_error: tstamp:2242259918 tag:CHANSEL_NOMATCH channel:0x01 frame:29 vi_tstamp:2242258030 data:0x00000569
kworker/1:4-1948 [001] .... 62.892789: rtcpu_vinotify_event: tstamp:2242604136 tag:FE channel:0x00 frame:28 vi_tstamp:2242257966 data:0x00000020
kworker/1:4-1948 [001] .... 62.892791: rtcpu_vinotify_event: tstamp:2242604302 tag:FS channel:0x00 frame:29 vi_tstamp:2242257987 data:0x00000010
kworker/1:4-1948 [001] .... 62.892792: rtcpu_vinotify_event: tstamp:2242604446 tag:CHANSEL_NOMATCH channel:0x01 frame:29 vi_tstamp:2242258030 data:0x00000569
kworker/1:4-1948 [001] .... 62.892794: rtcpu_vinotify_error: tstamp:2243065561 tag:CHANSEL_NOMATCH channel:0x01 frame:30 vi_tstamp:2243063643 data:0x00000569
kworker/1:4-1948 [001] .... 62.892795: rtcpu_vinotify_event: tstamp:2243301676 tag:FE channel:0x00 frame:29 vi_tstamp:2243063579 data:0x00000020
kworker/1:4-1948 [001] .... 62.892796: rtcpu_vinotify_event: tstamp:2243301818 tag:FS channel:0x00 frame:30 vi_tstamp:2243063600 data:0x00000010
kworker/1:4-1948 [001] .... 62.892829: rtcpu_vinotify_event: tstamp:2243301985 tag:CHANSEL_NOMATCH channel:0x01 frame:30 vi_tstamp:2243063643 data:0x00000569
kworker/1:4-1948 [001] .... 62.948875: rtcpu_vinotify_error: tstamp:2243871283 tag:CHANSEL_NOMATCH channel:0x01 frame:31 vi_tstamp:2243869256 data:0x00000569
kworker/1:4-1948 [001] .... 62.948879: rtcpu_vinotify_event: tstamp:2243871645 tag:FE channel:0x00 frame:30 vi_tstamp:2243869192 data:0x00000020
kworker/1:4-1948 [001] .... 62.948917: rtcpu_vinotify_event: tstamp:2243871812 tag:FS channel:0x00 frame:31 vi_tstamp:2243869213 data:0x00000010
kworker/1:4-1948 [001] .... 62.948918: rtcpu_vinotify_event: tstamp:2243871955 tag:CHANSEL_NOMATCH channel:0x01 frame:31 vi_tstamp:2243869256 data:0x00000569
kworker/1:4-1948 [001] .... 62.948921: rtos_queue_peek_from_isr_failed: tstamp:2243921385 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 62.948923: rtcpu_vinotify_error: tstamp:2244676768 tag:CHANSEL_NOMATCH channel:0x01 frame:32 vi_tstamp:2244674869 data:0x00000569
kworker/1:4-1948 [001] .... 62.948924: rtcpu_vinotify_event: tstamp:2244696676 tag:FE channel:0x00 frame:31 vi_tstamp:2244674804 data:0x00000020
kworker/1:4-1948 [001] .... 62.948925: rtcpu_vinotify_event: tstamp:2244696818 tag:FS channel:0x00 frame:32 vi_tstamp:2244674825 data:0x00000010
kworker/1:4-1948 [001] .... 62.948926: rtcpu_vinotify_event: tstamp:2244696984 tag:CHANSEL_NOMATCH channel:0x01 frame:32 vi_tstamp:2244674869 data:0x00000569
kworker/1:4-1948 [001] .... 62.948927: rtcpu_vinotify_error: tstamp:2245482395 tag:CHANSEL_NOMATCH channel:0x01 frame:33 vi_tstamp:2245480481 data:0x00000569
kworker/1:4-1948 [001] .... 63.005096: rtcpu_vinotify_event: tstamp:2245742947 tag:FE channel:0x00 frame:32 vi_tstamp:2245480417 data:0x00000020
kworker/1:4-1948 [001] .... 63.005103: rtcpu_vinotify_event: tstamp:2245743118 tag:FS channel:0x00 frame:33 vi_tstamp:2245480438 data:0x00000010
kworker/1:4-1948 [001] .... 63.005104: rtcpu_vinotify_event: tstamp:2245743263 tag:CHANSEL_NOMATCH channel:0x01 frame:33 vi_tstamp:2245480481 data:0x00000569
kworker/1:4-1948 [001] .... 63.005110: rtcpu_vinotify_error: tstamp:2246287992 tag:CHANSEL_NOMATCH channel:0x01 frame:34 vi_tstamp:2246286094 data:0x00000569
kworker/1:4-1948 [001] .... 63.005112: rtcpu_vinotify_event: tstamp:2246440451 tag:FE channel:0x00 frame:33 vi_tstamp:2246286030 data:0x00000020
kworker/1:4-1948 [001] .... 63.005113: rtcpu_vinotify_event: tstamp:2246440592 tag:FS channel:0x00 frame:34 vi_tstamp:2246286051 data:0x00000010
kworker/1:4-1948 [001] .... 63.005114: rtcpu_vinotify_event: tstamp:2246440758 tag:CHANSEL_NOMATCH channel:0x01 frame:34 vi_tstamp:2246286094 data:0x00000569
kworker/1:4-1948 [001] .... 63.005115: rtcpu_vinotify_error: tstamp:2247093606 tag:CHANSEL_NOMATCH channel:0x01 frame:35 vi_tstamp:2247091707 data:0x00000569
kworker/1:4-1948 [001] .... 63.005116: rtcpu_vinotify_event: tstamp:2247137974 tag:FE channel:0x00 frame:34 vi_tstamp:2247091644 data:0x00000020
kworker/1:4-1948 [001] .... 63.005117: rtcpu_vinotify_event: tstamp:2247138140 tag:FS channel:0x00 frame:35 vi_tstamp:2247091664 data:0x00000010
kworker/1:4-1948 [001] .... 63.005119: rtcpu_vinotify_event: tstamp:2247138283 tag:CHANSEL_NOMATCH channel:0x01 frame:35 vi_tstamp:2247091707 data:0x00000569
kworker/1:4-1948 [001] .... 63.061279: rtcpu_vinotify_error: tstamp:2247899236 tag:CHANSEL_NOMATCH channel:0x01 frame:36 vi_tstamp:2247897320 data:0x00000569
kworker/1:4-1948 [001] .... 63.061285: rtcpu_vinotify_event: tstamp:2248184250 tag:FE channel:0x00 frame:35 vi_tstamp:2247897256 data:0x00000020
kworker/1:4-1948 [001] .... 63.061286: rtcpu_vinotify_event: tstamp:2248184393 tag:FS channel:0x00 frame:36 vi_tstamp:2247897277 data:0x00000010
kworker/1:4-1948 [001] .... 63.061287: rtcpu_vinotify_event: tstamp:2248184560 tag:CHANSEL_NOMATCH channel:0x01 frame:36 vi_tstamp:2247897320 data:0x00000569
kworker/1:4-1948 [001] .... 63.061288: rtcpu_vinotify_error: tstamp:2248704963 tag:CHANSEL_NOMATCH channel:0x01 frame:37 vi_tstamp:2248702933 data:0x00000569
kworker/1:4-1948 [001] .... 63.061290: rtcpu_vinotify_event: tstamp:2248705299 tag:FE channel:0x00 frame:36 vi_tstamp:2248702869 data:0x00000020
kworker/1:4-1948 [001] .... 63.061294: rtos_queue_peek_from_isr_failed: tstamp:2248921361 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 63.061296: rtcpu_vinotify_event: tstamp:2249021479 tag:FS channel:0x00 frame:37 vi_tstamp:2248702889 data:0x00000010
kworker/1:4-1948 [001] .... 63.061329: rtcpu_vinotify_event: tstamp:2249021623 tag:CHANSEL_NOMATCH channel:0x01 frame:37 vi_tstamp:2248702933 data:0x00000569
kworker/1:4-1948 [001] .... 63.117508: rtcpu_vinotify_error: tstamp:2249510448 tag:CHANSEL_NOMATCH channel:0x01 frame:38 vi_tstamp:2249508545 data:0x00000569
kworker/1:4-1948 [001] .... 63.117513: rtcpu_vinotify_event: tstamp:2249719045 tag:FE channel:0x00 frame:37 vi_tstamp:2249508482 data:0x00000020
kworker/1:4-1948 [001] .... 63.117514: rtcpu_vinotify_event: tstamp:2249719188 tag:FS channel:0x00 frame:38 vi_tstamp:2249508502 data:0x00000010
kworker/1:4-1948 [001] .... 63.117551: rtcpu_vinotify_event: tstamp:2249719354 tag:CHANSEL_NOMATCH channel:0x01 frame:38 vi_tstamp:2249508545 data:0x00000569
kworker/1:4-1948 [001] .... 63.117552: rtcpu_vinotify_error: tstamp:2250316060 tag:CHANSEL_NOMATCH channel:0x01 frame:39 vi_tstamp:2250314158 data:0x00000569
kworker/1:4-1948 [001] .... 63.117553: rtcpu_vinotify_event: tstamp:2250416549 tag:FE channel:0x00 frame:38 vi_tstamp:2250314095 data:0x00000020
kworker/1:4-1948 [001] .... 63.117555: rtcpu_vinotify_event: tstamp:2250416715 tag:FS channel:0x00 frame:39 vi_tstamp:2250314115 data:0x00000010
kworker/1:4-1948 [001] .... 63.117556: rtcpu_vinotify_event: tstamp:2250416858 tag:CHANSEL_NOMATCH channel:0x01 frame:39 vi_tstamp:2250314158 data:0x00000569
kworker/1:4-1948 [001] .... 63.173728: rtcpu_vinotify_error: tstamp:2251121659 tag:CHANSEL_NOMATCH channel:0x01 frame:40 vi_tstamp:2251119771 data:0x00000569
kworker/1:4-1948 [001] .... 63.173735: rtcpu_vinotify_event: tstamp:2251462789 tag:FE channel:0x00 frame:39 vi_tstamp:2251119707 data:0x00000020
kworker/1:4-1948 [001] .... 63.173736: rtcpu_vinotify_event: tstamp:2251462931 tag:FS channel:0x00 frame:40 vi_tstamp:2251119728 data:0x00000010
kworker/1:4-1948 [001] .... 63.173738: rtcpu_vinotify_event: tstamp:2251463100 tag:CHANSEL_NOMATCH channel:0x01 frame:40 vi_tstamp:2251119771 data:0x00000569
kworker/1:4-1948 [001] .... 63.173739: rtcpu_vinotify_error: tstamp:2251927284 tag:CHANSEL_NOMATCH channel:0x01 frame:41 vi_tstamp:2251925384 data:0x00000569
kworker/1:4-1948 [001] .... 63.173740: rtcpu_vinotify_event: tstamp:2252160346 tag:FE channel:0x00 frame:40 vi_tstamp:2251925320 data:0x00000020
kworker/1:4-1948 [001] .... 63.173741: rtcpu_vinotify_event: tstamp:2252160513 tag:FS channel:0x00 frame:41 vi_tstamp:2251925341 data:0x00000010
kworker/1:4-1948 [001] .... 63.173742: rtcpu_vinotify_event: tstamp:2252160654 tag:CHANSEL_NOMATCH channel:0x01 frame:41 vi_tstamp:2251925384 data:0x00000569
kworker/1:4-1948 [001] .... 63.229914: rtcpu_vinotify_error: tstamp:2252733030 tag:CHANSEL_NOMATCH channel:0x01 frame:42 vi_tstamp:2252730997 data:0x00000569
kworker/1:4-1948 [001] .... 63.229922: rtcpu_vinotify_event: tstamp:2252733372 tag:FE channel:0x00 frame:41 vi_tstamp:2252730933 data:0x00000020
kworker/1:4-1948 [001] .... 63.229923: rtcpu_vinotify_event: tstamp:2252733518 tag:FS channel:0x00 frame:42 vi_tstamp:2252730954 data:0x00000010
kworker/1:4-1948 [001] .... 63.229924: rtcpu_vinotify_event: tstamp:2253067580 tag:CHANSEL_NOMATCH channel:0x01 frame:42 vi_tstamp:2252730997 data:0x00000569
kworker/1:4-1948 [001] .... 63.229925: rtcpu_vinotify_error: tstamp:2253538507 tag:CHANSEL_NOMATCH channel:0x01 frame:43 vi_tstamp:2253536609 data:0x00000569
kworker/1:4-1948 [001] .... 63.229927: rtcpu_vinotify_event: tstamp:2253765096 tag:FE channel:0x00 frame:42 vi_tstamp:2253536546 data:0x00000020
kworker/1:4-1948 [001] .... 63.229928: rtcpu_vinotify_event: tstamp:2253765264 tag:FS channel:0x00 frame:43 vi_tstamp:2253536567 data:0x00000010
kworker/1:4-1948 [001] .... 63.229929: rtcpu_vinotify_event: tstamp:2253765408 tag:CHANSEL_NOMATCH channel:0x01 frame:43 vi_tstamp:2253536609 data:0x00000569
kworker/1:4-1948 [001] .... 63.229932: rtos_queue_peek_from_isr_failed: tstamp:2253921366 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 63.286129: rtcpu_vinotify_error: tstamp:2254344124 tag:CHANSEL_NOMATCH channel:0x01 frame:44 vi_tstamp:2254342222 data:0x00000569
kworker/1:4-1948 [001] .... 63.286135: rtcpu_vinotify_event: tstamp:2254462638 tag:FE channel:0x00 frame:43 vi_tstamp:2254342159 data:0x00000020
kworker/1:4-1948 [001] .... 63.286136: rtcpu_vinotify_event: tstamp:2254462782 tag:FS channel:0x00 frame:44 vi_tstamp:2254342180 data:0x00000010
kworker/1:4-1948 [001] .... 63.286138: rtcpu_vinotify_event: tstamp:2254462948 tag:CHANSEL_NOMATCH channel:0x01 frame:44 vi_tstamp:2254342222 data:0x00000569
kworker/1:4-1948 [001] .... 63.286139: rtcpu_vinotify_error: tstamp:2255149735 tag:CHANSEL_NOMATCH channel:0x01 frame:45 vi_tstamp:2255147836 data:0x00000569
kworker/1:4-1948 [001] .... 63.286140: rtcpu_vinotify_event: tstamp:2255160145 tag:FE channel:0x00 frame:44 vi_tstamp:2255147771 data:0x00000020
kworker/1:4-1948 [001] .... 63.286141: rtcpu_vinotify_event: tstamp:2255160341 tag:FS channel:0x00 frame:45 vi_tstamp:2255147793 data:0x00000010
kworker/1:4-1948 [001] .... 63.286142: rtcpu_vinotify_event: tstamp:2255160483 tag:CHANSEL_NOMATCH channel:0x01 frame:45 vi_tstamp:2255147836 data:0x00000569
kworker/1:4-1948 [001] .... 63.286143: rtcpu_vinotify_error: tstamp:2255955360 tag:CHANSEL_NOMATCH channel:0x01 frame:46 vi_tstamp:2255953449 data:0x00000569
kworker/1:4-1948 [001] .... 63.342335: rtcpu_vinotify_event: tstamp:2256206409 tag:FE channel:0x00 frame:45 vi_tstamp:2255953384 data:0x00000020
kworker/1:4-1948 [001] .... 63.342341: rtcpu_vinotify_event: tstamp:2256206553 tag:FS channel:0x00 frame:46 vi_tstamp:2255953405 data:0x00000010
kworker/1:4-1948 [001] .... 63.342342: rtcpu_vinotify_event: tstamp:2256206719 tag:CHANSEL_NOMATCH channel:0x01 frame:46 vi_tstamp:2255953449 data:0x00000569
kworker/1:4-1948 [001] .... 63.342344: rtcpu_vinotify_error: tstamp:2256761086 tag:CHANSEL_NOMATCH channel:0x01 frame:47 vi_tstamp:2256759061 data:0x00000569
kworker/1:4-1948 [001] .... 63.342345: rtcpu_vinotify_event: tstamp:2256761426 tag:FE channel:0x00 frame:46 vi_tstamp:2256758997 data:0x00000020
kworker/1:4-1948 [001] .... 63.342347: rtcpu_vinotify_event: tstamp:2256761592 tag:FS channel:0x00 frame:47 vi_tstamp:2256759018 data:0x00000010
kworker/1:4-1948 [001] .... 63.342348: rtcpu_vinotify_event: tstamp:2256761732 tag:CHANSEL_NOMATCH channel:0x01 frame:47 vi_tstamp:2256759061 data:0x00000569
kworker/1:4-1948 [001] .... 63.342349: rtcpu_vinotify_error: tstamp:2257567647 tag:CHANSEL_NOMATCH channel:0x01 frame:48 vi_tstamp:2257564674 data:0x00000569
kworker/1:4-1948 [001] .... 63.342350: rtcpu_vinotify_event: tstamp:2257568179 tag:FE channel:0x00 frame:47 vi_tstamp:2257564610 data:0x00000020
kworker/1:4-1948 [001] .... 63.342351: rtcpu_vinotify_event: tstamp:2257568319 tag:FS channel:0x00 frame:48 vi_tstamp:2257564631 data:0x00000010
kworker/1:4-1948 [001] .... 63.342352: rtcpu_vinotify_event: tstamp:2257568485 tag:CHANSEL_NOMATCH channel:0x01 frame:48 vi_tstamp:2257564674 data:0x00000569
kworker/1:4-1948 [001] .... 63.398552: rtcpu_vinotify_error: tstamp:2258372181 tag:CHANSEL_NOMATCH channel:0x01 frame:49 vi_tstamp:2258370287 data:0x00000569
kworker/1:4-1948 [001] .... 63.398558: rtcpu_vinotify_event: tstamp:2258612672 tag:FE channel:0x00 frame:48 vi_tstamp:2258370223 data:0x00000020
kworker/1:4-1948 [001] .... 63.398560: rtcpu_vinotify_event: tstamp:2258612841 tag:FS channel:0x00 frame:49 vi_tstamp:2258370244 data:0x00000010
kworker/1:4-1948 [001] .... 63.398561: rtcpu_vinotify_event: tstamp:2258612986 tag:CHANSEL_NOMATCH channel:0x01 frame:49 vi_tstamp:2258370287 data:0x00000569
kworker/1:4-1948 [001] .... 63.398564: rtos_queue_peek_from_isr_failed: tstamp:2258921366 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 63.398565: rtcpu_vinotify_error: tstamp:2259177799 tag:CHANSEL_NOMATCH channel:0x01 frame:50 vi_tstamp:2259175900 data:0x00000569
kworker/1:4-1948 [001] .... 63.398566: rtcpu_vinotify_event: tstamp:2259310201 tag:FE channel:0x00 frame:49 vi_tstamp:2259175836 data:0x00000020
kworker/1:4-1948 [001] .... 63.398567: rtcpu_vinotify_event: tstamp:2259310346 tag:FS channel:0x00 frame:50 vi_tstamp:2259175857 data:0x00000010
kworker/1:4-1948 [001] .... 63.398569: rtcpu_vinotify_event: tstamp:2259310513 tag:CHANSEL_NOMATCH channel:0x01 frame:50 vi_tstamp:2259175900 data:0x00000569
kworker/1:4-1948 [001] .... 63.454745: rtcpu_vinotify_error: tstamp:2259983413 tag:CHANSEL_NOMATCH channel:0x01 frame:51 vi_tstamp:2259981513 data:0x00000569
kworker/1:4-1948 [001] .... 63.454752: rtcpu_vinotify_event: tstamp:2260008241 tag:FE channel:0x00 frame:50 vi_tstamp:2259981449 data:0x00000020
kworker/1:4-1948 [001] .... 63.454754: rtcpu_vinotify_event: tstamp:2260008409 tag:FS channel:0x00 frame:51 vi_tstamp:2259981469 data:0x00000010
kworker/1:4-1948 [001] .... 63.454755: rtcpu_vinotify_event: tstamp:2260008551 tag:CHANSEL_NOMATCH channel:0x01 frame:51 vi_tstamp:2259981513 data:0x00000569
kworker/1:4-1948 [001] .... 63.454756: rtcpu_vinotify_error: tstamp:2260789022 tag:CHANSEL_NOMATCH channel:0x01 frame:52 vi_tstamp:2260787125 data:0x00000569
kworker/1:4-1948 [001] .... 63.454757: rtcpu_vinotify_event: tstamp:2261054503 tag:FE channel:0x00 frame:51 vi_tstamp:2260787062 data:0x00000020
kworker/1:4-1948 [001] .... 63.454759: rtcpu_vinotify_event: tstamp:2261054647 tag:FS channel:0x00 frame:52 vi_tstamp:2260787082 data:0x00000010
kworker/1:4-1948 [001] .... 63.454760: rtcpu_vinotify_event: tstamp:2261054817 tag:CHANSEL_NOMATCH channel:0x01 frame:52 vi_tstamp:2260787125 data:0x00000569
kworker/1:4-1948 [001] .... 63.510945: rtcpu_vinotify_error: tstamp:2261594769 tag:CHANSEL_NOMATCH channel:0x01 frame:53 vi_tstamp:2261592738 data:0x00000569
kworker/1:4-1948 [001] .... 63.510952: rtcpu_vinotify_event: tstamp:2261595106 tag:FE channel:0x00 frame:52 vi_tstamp:2261592675 data:0x00000020
kworker/1:4-1948 [001] .... 63.510953: rtcpu_vinotify_event: tstamp:2261926204 tag:FS channel:0x00 frame:53 vi_tstamp:2261592695 data:0x00000010
kworker/1:4-1948 [001] .... 63.510990: rtcpu_vinotify_event: tstamp:2261926344 tag:CHANSEL_NOMATCH channel:0x01 frame:53 vi_tstamp:2261592738 data:0x00000569
kworker/1:4-1948 [001] .... 63.510992: rtcpu_vinotify_error: tstamp:2262400247 tag:CHANSEL_NOMATCH channel:0x01 frame:54 vi_tstamp:2262398351 data:0x00000569
kworker/1:4-1948 [001] .... 63.510993: rtcpu_vinotify_event: tstamp:2262623722 tag:FE channel:0x00 frame:53 vi_tstamp:2262398287 data:0x00000020
kworker/1:4-1948 [001] .... 63.510994: rtcpu_vinotify_event: tstamp:2262623865 tag:FS channel:0x00 frame:54 vi_tstamp:2262398308 data:0x00000010
kworker/1:4-1948 [001] .... 63.510995: rtcpu_vinotify_event: tstamp:2262624031 tag:CHANSEL_NOMATCH channel:0x01 frame:54 vi_tstamp:2262398351 data:0x00000569
kworker/1:4-1948 [001] .... 63.567137: rtcpu_vinotify_error: tstamp:2263205863 tag:CHANSEL_NOMATCH channel:0x01 frame:55 vi_tstamp:2263203964 data:0x00000569
kworker/1:4-1948 [001] .... 63.567144: rtcpu_vinotify_event: tstamp:2263321243 tag:FE channel:0x00 frame:54 vi_tstamp:2263203900 data:0x00000020
kworker/1:4-1948 [001] .... 63.567145: rtcpu_vinotify_event: tstamp:2263321409 tag:FS channel:0x00 frame:55 vi_tstamp:2263203921 data:0x00000010
kworker/1:4-1948 [001] .... 63.567146: rtcpu_vinotify_event: tstamp:2263321552 tag:CHANSEL_NOMATCH channel:0x01 frame:55 vi_tstamp:2263203964 data:0x00000569
kworker/1:4-1948 [001] .... 63.567181: rtos_queue_peek_from_isr_failed: tstamp:2263921366 queue:0x0bcc8ef0
kworker/1:4-1948 [001] .... 63.567184: rtcpu_vinotify_error: tstamp:2264011479 tag:CHANSEL_NOMATCH channel:0x01 frame:56 vi_tstamp:2264009576 data:0x00000569
kworker/1:4-1948 [001] .... 63.567186: rtcpu_vinotify_event: tstamp:2264018764 tag:FE channel:0x00 frame:55 vi_tstamp:2264009513 data:0x00000020
kworker/1:4-1948 [001] .... 63.567187: rtcpu_vinotify_event: tstamp:2264018908 tag:FS channel:0x00 frame:56 vi_tstamp:2264009533 data:0x00000010
kworker/1:4-1948 [001] .... 63.567188: rtcpu_vinotify_event: tstamp:2264019075 tag:CHANSEL_NOMATCH channel:0x01 frame:56 vi_tstamp:2264009576 data:0x00000569
kworker/1:4-1948 [001] .... 63.567190: rtcpu_vinotify_error: tstamp:2264817087 tag:CHANSEL_NOMATCH channel:0x01 frame:57 vi_tstamp:2264815189 data:0x00000569
kworker/1:4-1948 [001] .... 63.623348: rtcpu_vinotify_event: tstamp:2265065029 tag:FE channel:0x00 frame:56 vi_tstamp:2264815126 data:0x00000020
kworker/1:4-1948 [001] .... 63.623353: rtcpu_vinotify_event: tstamp:2265065197 tag:FS channel:0x00 frame:57 vi_tstamp:2264815147 data:0x00000010
kworker/1:4-1948 [001] .... 63.623354: rtcpu_vinotify_event: tstamp:2265065341 tag:CHANSEL_NOMATCH channel:0x01 frame:57 vi_tstamp:2264815189 data:0x00000569
kworker/1:4-1948 [001] .... 63.623357: rtcpu_vinotify_error: tstamp:2265622852 tag:CHANSEL_NOMATCH channel:0x01 frame:58 vi_tstamp:2265620802 data:0x00000569
kworker/1:4-1948 [001] .... 63.623358: rtcpu_vinotify_event: tstamp:2265623195 tag:FE channel:0x00 frame:57 vi_tstamp:2265620739 data:0x00000020
kworker/1:4-1948 [001] .... 63.623359: rtcpu_vinotify_event: tstamp:2265623340 tag:FS channel:0x00 frame:58 vi_tstamp:2265620760 data:0x00000010
kworker/1:4-1948 [001] .... 63.623361: rtcpu_vinotify_event: tstamp:2265937257 tag:CHANSEL_NOMATCH channel:0x01 frame:58 vi_tstamp:2265620802 data:0x00000569
kworker/1:4-1948 [001] .... 63.623362: rtcpu_vinotify_error: tstamp:2266428332 tag:CHANSEL_NOMATCH channel:0x01 frame:59 vi_tstamp:2266426415 data:0x00000569
kworker/1:4-1948 [001] .... 63.679547: rtcpu_vinotify_event: tstamp:2266634781 tag:FE channel:0x00 frame:58 vi_tstamp:2266426351 data:0x00000020
kworker/1:4-1948 [001] .... 63.679553: rtcpu_vinotify_event: tstamp:2266634949 tag:FS channel:0x00 frame:59 vi_tstamp:2266426373 data:0x00000010
kworker/1:4-1948 [001] .... 63.679555: rtcpu_vinotify_event: tstamp:2266635090 tag:CHANSEL_NOMATCH channel:0x01 frame:59 vi_tstamp:2266426415 data:0x00000569
kworker/1:4-1948 [001] .... 63.679589: rtc
