Double eDP output in TX2
Both eDP and HDMI can be output now,but boss want to use double eDP(not DP) output
questions:Can HDMI output be changed to eDP output? If can, how do I modify it?
zbm2007,
Yes, it should work. Though it is not under verification.
Please refer to the device tree of eDP and copy it to nvdisplay and sor which are corresponding to your HDMI.
If you already enabled eDP on TX2, then enable for another one should be easy too. Please note the parent clk may need to be changed.
Thanks Wayne,
I solved it.Do as you say, I modified the device tree, and pinmux also needs to be modified.
