I try to use the double function for atomicAdd
__device__ double GPUInfo::atomicAddDouble(double* address, double val)
double old = *address, assumed;
do {
assumed = old;
old =
__longlong_as_double(
atomicCAS((unsigned long long int*)address,
__double_as_longlong(assumed),
__double_as_longlong(val + assumed)));
} while (assumed != old);
return old;
The argument
-gencode arch=compute_13,code=sm_13
has been added in the flag field of NVCC compiler.
But, I got this error:
Description Resource Path Location Type
identifier “__double_as_longlong” is undefined GPUInformation.cu /MatchedFilter/Source line 31 C/C++ Problem
identifier “__longlong_as_double” is undefined GPUInformation.cu /MatchedFilter/Source line 29 C/C++ Problem
no instance of overloaded function “atomicCAS” matches the argument list GPUInformation.cu /MatchedFilter/Source line 30 C/C++ Problem
make: *** [Source/cu_GPUInformation.o] Error 2 MatchedFilter line 0 C/C++ Problem
I use eclipse with nvcc 3.2 on Ubuntu 10.10.
