Double screen stopped working and Failed to initialize NVML: Driver/library version mismatch
nvidia-bug-report.log (1.5 MB)
suddenly this afternoon, my computer kinda crashed (it rebooted out of nowhere), and then my double screen stopped working, and then I tried to run nvidia-smi and it returned the following error message : Failed to initialize NVML: Driver/library version mismatch
Processing: nvidia-bug-report.log.gz…
Is there a procedure I can follow to fix my broken nvidia ?
I tried rebooting the computer already, and I do not recall installing anything that could possibly have killed nvidia
I have the 535.86.05 version of the kernel module, which was installed after double screen issues (double screen not detected)
Thank you for your time,
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Fri Aug 18 16:58:23 2023
installer version: 530.41.03
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Detected 16 CPUs online; setting concurrency level to 16.
→ Installing NVIDIA driver version 530.41.03.
→ There appears to already be a driver installed on your system (version: 535.98). As part of installing this driver (version: 530.41.03), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the “Software & Updates” application, and by selecting the NVIDIA driver from the “Additional Drivers” tab.
You installed the nvidia driver 530 via .run file, over the distro package 535.
You ignored the warnings, that messed up your system.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
Then you created an Xorg config, which is totally unusable for mixed graphics laptops (Optimus laptops).
1: delete: /etc/X11/xorg.conf
2: Use the .run file of the 530 version to uninstall that version of the driver.
3: run in a terminal:
sudo apt purge 'nvidia*' 'libnvidia*'
4: sudo apt install nvidia-driver-535
5: reboot
