Hello.
I have the following Fortran code:
!$acc region copy(sh_c(:,iw0)),copyin(con_c(:,iw0)),copyout(cat_cx,cat_rx)
cat_rx%cat1 = 0.
cat_rx%cat2 = 0.
cat_rx%cat3 = 0.
cat_rx%cat4 = 0.
cat_rx%cat5 = 0.
cat_rx%cat6 = 0.
cat_rx%cat7 = 0.
cat_cx%cat1 = 0.
cat_cx%cat2 = 0.
cat_cx%cat3 = 0.
cat_cx%cat4 = 0.
cat_cx%cat5 = 0.
cat_cx%cat6 = 0.
cat_cx%cat7 = 0.
if (jnmb(1) >= 1) then
do k = lpw0,mza0
if (sh_c(k,iw0) >= rxmin(1)) then
cat_rx(k)%cat1 = sh_c(k,iw0) * rhoa(k)
if (jnmb(1) >= 5) cat_cx(k)%cat1 = con_c(k,iw0) * rhoa(k)
elseif (sh_c(k,iw0) < 0.) then
sh_c(k,iw0) = 0.
endif
enddo
endif
!$acc end region
This produce right results. Changing:
to:
!$acc region copy(sh_c(lpw0:mza0,iw0)),copyin(con_c(lpw0:mza0,iw0)),copyout(cat_cx,cat_rx)
produces wrong results, or even a segmentation fault.
The compiler shows a similar construction when the statement is:
!$acc region copyout(cat_cx,cat_rx)
Producing the following message:
mic_copy:
937, Generating copyout(cat_rx(:))
Generating copyout(cat_cx(:))
938, Generating copyin(rhoa(lpw0:mza0))
Generating copy(sh_c(lpw0:mza0,iw0))
Generating copyin(rxmin(1))
Generating copyin(con_c(lpw0:mza0,iw0))
Generating copyin(jnmb(1))
Generating compute capability 1.3 binary
The sh_c and con_c variables are coming from modules.
Is the accelerator copy task misaligned? How can I produce correct results copying just a part of the matrix?
Thanks a lot!
