Hello All,
This may be a silly doubt for many of you, but I want to clear it and be sure of what I am doing.
Suppose we want to use the CUBLAS level 1 function say finding the norm for example
now suppose I use a cuDoubleComplex as my data type in that case I will call cublasDzmrm2() function to calculate the norm.
The declaration of the function in the library is
cublasStatus_t cublasDznrm2(cublasHandle_t handle, int n, const cuDoubleComplex *x, int incx, double result);
the documentation say that the fourth parameter “int incx” is for “stride between the elements of x”.
now if my array is having cuDoubleComplex data type and all elements are stored at consecutive location. what should be the value of incx ?
incx = 0 or 1 or 8 or 16 (since its cuDoubleComplex). whats the correct answer?
Thanks in advance
Walter
