Downgrade JetPack 7.2 to JetPack 6.2
I’m currently using JetPack 6.2 on my Jetson Orin Nano Developer Kit and would like to try JetPack 7.2. However, I’m concerned about how easily I can roll back if something goes wrong.
Is it possible to downgrade from JetPack 7.2 back to JetPack 6.2?
Can I simply come back with a JetPack 6.2 microSD card image, or would I need to use SDK Manager to do the downgrade?
Yes, downgrading from JetPack 7.2 to JetPack 6.2 is possible, but it is not an in-place downgrade.
  1. Back up your data
    A full flash erases the target storage, so please back up any data you need before upgrading or downgrading.
  2. Use SDK Manager for the downgrade
    Use SDK Manager to perform a full JetPack 6.2 flash. This restores both the QSPI boot firmware and the operating system image to compatible JetPack 6.2 versions.
Simply replacing the microSD card with a JetPack 6.2 image is not the documented rollback path because it does not restore the QSPI firmware from JetPack 7.2 to the JetPack 6.2 version.
Hope this helps!
That’s a relief. Thanks for the reply.
