Downgrading from jp6 to 5. SDK manager hangs at 99% percent and flashing with balena etcher results in a black screen. Jetson Orin nano
I am trying to get an intel real sense camera to work on my jetson orin nano but have been having issues, jp6 is not currently supported so I am trying to go back to any version of jp5 , as intel real sense seems to support it. The sdk manager freezes at 99% indefinitely and when I flash the sd card manually it black screens after the boot loader screen. I think I might need to flash the previous firmware to the board but have had no luck finding resources to do that, and it seems most people just have the sdk manager work for the downgrade process. Any help would be a appreciated.
Googling Jetson SDK Manager gives you:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
Does not work. It is the same instructions for regular install. As stated it freezes at 99%. If the sdk is able to flash the firmware then why do you have to install jet pack 5.1.3 before upgrading to 6.0. I am talking about the boot-loader or as referred to in the setup guide the firmware.
Then put the log.
There is no way we can help you without any log.
