We worked with OSRF to enable a version of ROS on Jetson TX1 with 64-bit BSP. Since compiling and testing a ROS config (consisting of platform/instruction set, ROS version, and Ubuntu version; accordingly there are many permutations to test) takes lots of compute resources (pricey VPS time), OSRF opted to build and test only ROS Kinetic on Ubuntu 16.04 LTS, leaving Indigo+14.04 on 32-bit ARM (armhf) only.
You should be able to compile ROS Indigo from source, but doing so on Ubuntu 16.04 LTS may have some dependency issues. Some dependencies may be too new for what Indigo expects. I don’t believe OSRF has plans to support ROS Indigo on 16.04 LTS, especially not on ARM 64-bit (aarch64).
