Downgrading Jetpack version on Jetson Orin Nano from 6.0 to 5.1.3
I wanted to downgrade the version of the Jetpack from 6.0 to 5.1.3. I tried with SDK manager but it returns installation failed. On the SD card there is Jetpack 6.0 version and it doesn’t want to downgrade. Also I tried with empty SD card but when it is empty I cannot choose my Jetson Orin Nano in the SDK manager. I will upload terminal logs as well.
SDKM_logs_JetPack_5.1.3_Linux_for_Jetson_Orin_Nano_modules_2024-07-01_15-22-54.zip (101.3 KB)
What does above comment try to tell? I really cannot understand what does this sentence mean…
You should put the board into recovery mode and let the x86 host PC detect it and flash.
But not relying on whether the sdcard is empty or not… Actually, whether the card is empty or not should not matter.
