Download Error on SDK Manager
hello, i have jetson agx orin dev kit 64gb, i completed the wsl/usb configuration so i can see my orin agx device listed on my wsl(lsusb). i tried both skd cli and docker image, both are getting http error at download, not sure why, i could see those links working yesterday.
There seems to be some issues on SDK manager server, and we’re fixing now. Thanks
Facing the same issue! thanks for looking into this, happy new year guys!
Also having the same issue - worked yesterday morning but doesn’t work today. Thanks for looking into this!
I’m still getting the same error.
links are working i had to switch to a wsl instance with ubuntu 22.04 sorry about that. now I’m facing a different issue but at flashing step. please close this ticket.
@dominusbelial I believe this is an unrelated issue. Follow this link to access your USB devices through WSL2. You may run into issues with autosuspend and have to change some configuration/recompile the kernel for WSL2.
In my opinion, using an actual Linux machine will make this much easier - second best option for me was a VM.
yup totally different issue now, i have ubuntu dual boot and just gave it a shot , im doing the same workflow from 24.04 with docker and sdkmanager-2.2.0.12028-Ubuntu_22.04_docker.tar.gz, but I’m getting some segmentation fault. will be posting a new ticket about it if i can’t get over this…
docker run -it --privileged -v /dev/bus/usb:/dev/bus/usb/ -v /dev:/dev -v /media/$USER:/media/nvidia:slave --name JetPack_AGX_Orin_Devkit --network host sdkmanager --cli --action install --login-type devzone --product Jetson --target-os Linux --version 6.1 --target JETSON_AGX_ORIN_TARGETS --flash --license accept --stay-logged-in true --collect-usage-data enable
