I am working with DS 6.0 and its Python bindings. I am running a primary detector on multiple streams. After that I have a nvstreamdemux element that split the batched data into individual stream’s data.
I want to retrieve the numpy image of each stream frame. I know how to do that using a probe. This works fine but it slows down the pipeline since the probe is blocking.
I was thing to add a queue after nvstreamdemux and right before the probe that retrieves the numpy frame. It is my understanding that the queue would create a new thread therefore avoid blocking the pipeline because of the subsequent slow probe.
However, is there any risk to encounter synchronization issue? Does the queue perform a deep copy of the data or does it just store the pointer to the data? If there’s no deep copy, I am afraid that there could be two concurrent access to the same memory location:
My probe retrieving the numpy frame
Nvstreammux (or another component) replacing the frame with a new one
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
