Downloaded jetson-inference library
When I downloaded jetson-inference library that I am using for face / object recognition I did not get the option to install the the Model Downloader. Did i do something wrong during then installation process.
Hi there @rjaffeco,
can you share which Jetson model you are using? Then I can refer you to the correct Jetson category here in the forums where people might be better able to help you.
