Downsampling over the sequence length in LSTMs
I am trying to build an architecture where I have 2 stacked LSTMs where the output sequence of the first cell is downsampled before going into the second cell.
For example if I have a sequence length of SEQ_LEN, the cell after it will get an entry with a sequence length of SEQ_LEN/2, such that we take the max between the vectors at positions 2k and 2k+1 in the output sequence of the first cell for each possible k.
I have searched in the documentation and didn’t find anything referring to this type of downsampling. Did I miss some parameter or some feature in the docs ? Or do I have to implement this logic myself ?
Thank you very much for your time !
In this case, you would need to implement this logic, maybe you can use the pooling to do the max pooling.
Thank you very much for your answer !
What If the downsampling is done by skipping every other timestep in the output of the first layer instead of using pooling. Do I just change the memory descriptor to get strided traversal to skip odd timesteps ?
Thank you in andvance for your time !
Sorry for late reply.
Is issue resolved? Does above mentioned approach worked in your case?
