DP Alt Mode on Jetson Orin Nano
We are trying to get the DP Alt mode working on our custom carrier board for Jetson Orin Nano 8GB.
I have verified the setup with USB PD protocol analyzer and USB PD messages look okay. DFP and UFP are managing to enter alt mode and configure the connection.
But I am getting the following error on Jetson and display out is not working
On connect:
[  133.190813] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.193929] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.197155] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.200253] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.203434] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.206507] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.209667] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.212724] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.216060] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.219365] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.222772] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.225893] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.229088] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.232150] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.235351] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
[  133.238418] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0x65:
On disconnect:
[  145.478722] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
On disconnect error is listed in the known issues and also appears on Devkit.
What could be the issue here?
Thank you!
Details:
Custom Carrier Board
Jetson Linux 36.3
USB C Controller: TPS65987D
DP ALT: TUSB546
dmesg_post_boot_hotplug.log (49.8 KB)
dmesg_dp_connected_pre_boot.log (49.6 KB)
DP Alt mode is not supported on any Orin platform.
Thank you for the reply @WayneWWW
Is it a hardware constraint or is it a software constraint/not tested?
This is never in the plan of Orin display.
