hi, from igx t5000 spec, it supports two shared dp/hdmi port, there are one DP and one HDMI at reference schematic, but the two usb type c(J82/J81) both have the DP net connection also. could usb type C support DP output or the USB DP connection need to be removed, thanks and br
Hi afd0001,
The official IGX T5000 documentation lists the supported display outputs as the dedicated DP and HDMI ports.
So for a custom carrier board, USB Type-C should not be treated as a default DP output.
If you do not plan to implement and validate full USB-C DP Alt Mode support, please remove the DP connection on J81/J82 and use the native DP/HDMI output instead.
hi, thanks for your help.
from the reference schematic, the USB DP ALT is DP3 and DP2. if we need to implement the usb dp, does we need to keep the same connection? the DP can switch from DP0/1 to DP3 or DP2 by IGX T5000 its own software? or we need to replace DP3/DP2 with DP1/DP0?
thanks and br
If you want to implement USB-C DP on your carrier board, please keep the same routing as the reference design.
On the reference schematic, J82/USBC1 is routed with DP2 and J81/USBC2 is routed with DP3. These are dedicated DP paths for the USB-C ports, not a software switch from DP0/DP1.
So please do not replace DP2/DP3 with DP0/DP1.
If you want USB-C DP Alt Mode support, please keep the same DP2/DP3 + AUX/HPD/PD/mux architecture as the reference design.
get it ,thanks for your help.
