See attached
montecarlo uses floats by defualt. run with -type=double
reduction uses integers by default. run with -type=float, -type-double or -type-int
I’d suggest installing beta 2.0 sdk and rename the montecarlo and reduction projects and drop these new ones in.
see makefile or vs2005 project settings (custom build steps) for examples of building with -arch sm_13
dp_reduce_monte.zip (50.9 KB)
