We want to use the display ports on Xavier to design DP++ ports. Does the Xavier support DP++ functionality? In that case how can we select between Aux and SCL and SDA lines?
No, Xavier does not support DP++ function.
But the datasheet mentions the following “Dual-Mode DisplayPort (DP++) can be supported, in which the DisplayPort connector logically
outputs TMDS signaling to a DP-to-HDMI dongle.”. Does that mean the bsp do not support DP++. In case of DP++ what changes are needed from usual hardware design.
Actually no such function in software function. I think the module datasheet needs to be updated.
