Platform: Jetson AGX Orin (Tegra234), L4T r36.5 / JetPack 6.2.2
Previous working version: L4T r36.4.4 / JetPack 6.2.1
Issue: Display output fails with passive DP-to-HDMI converters on JP6.2.2. Native DP-to-DP works fine on the same port.
Error from DMesg:
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Seems like the DpAuxchCtrl (0x731341) RPC fails repeatedly, preventing sink detection and EDID reads through the DP-to-HDMI converter.
Hello @daniel.chaves!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi @daniel.chaves
Thanks for reporting this. Since native DP-to-DP works on the same port but DP-to-HDMI converters fail on R36.5 / JetPack 6.2.2, this looks specific to the DP-to-HDMI adapter negotiation path.
The Jetson Linux R36.5 release notes also mention that some DP-to-HDMI converters may not work as expected with Jetson AGX Orin, so could you first share the exact adapter vendor and model you are using?
Please also try one isolation test on R36.5:
Remove hdcp_enabled; from the display device tree
We have seen a related AGX Orin DP-to-HDMI case where this property affected adapter compatibility. This is not confirmed as the root cause for your case yet, but it is a useful check.
Also, L4T does not actually support HDCP, so removing this property should not remove functional HDCP support.
If the issue still reproduces, please collect comparison logs
Please collect the following from both:
- R36.4.4 / JetPack 6.2.1, where the same adapter works
- R36.5 / JetPack 6.2.2, where the same adapter fails
xrandr --verbose
dmesg | grep -iE "nvrm|dce|dpaux|dp|hpd|edid|display|nvdisplay"
If possible, please also provide the EDID sysfs output for the DP connector on both releases.
Recommendation: please start with the adapter make/model and the hdcp_enabled; test. If that does not change the behavior, the R36.4.4 vs R36.5 logs will help us compare where sink detection or AUX/EDID handling starts to differ.
Hope this helps!
Thank you! After removing the HDCP property it worked for me.
Daniel
