I’m using DPDK with the MLX5 PMD to receive UDP packets. In order to receive UDP packets only, I use DPDK’s Flow API, which requires starting the port before configuration (rte_eth_dev_start).
The thing is that I don’t actually want to start receiving packets as soon as the port is started, but only do this because it is advised before using the Flow API.
RX queue 0 still starts on rte_eth_dev_start, and packets are received even if do not call rte_eth_dev_rx_queue_start. No commit seems to change this behaviour up to the latest DPDK version at the time of writing (23.03).
After a quick look in the code, rx_deferred_start seems to be mentionned only by the MLX5 PMD for configuration getter, not setters.
Is it intended ? (limitations in mlx5 ?)
Could it be fixed in a future version ?
Thank you for the information. Could you at least document this as a limitation of the MLX5 PMD ? I may be wrong but I found no mention of this.
Can you share any details about the reason of this limitation ? I’m not familiar with MNLX_OFED programming, but does the limitation stems from the driver, or only that it has not been wrapped in DPDK ? I could provide an implementation in the latter situation.
Hi, Julien
Deferred start is imposed to provide late queue setup, after device start.
mlx5 PMD does not support deferred start - all queues must be configured before device start.
I would recommend to consider the following scenarios:
Scenario A - using queue stop/start
configure queues
rte_eth_dev_start
rte_eth_rx_queue_stop
no traffic will be received on the stopped queues
configure flows
rte_eth_rx_queue_start
Scenario B - using isolated mode
configure queues
rte_flow_isolate
rte_eth_dev_start
configure flows
traffic will appear once the specific queue/RSS is specified in Flow being applied
Scenario C - do not call rx_burst till flows configured
start device
configure flows
drain Rx queues until timeout/max number of packets
Thanks for all of these details, this is very informative. I didn’t know that deferred start provided late queue setup, I understood it as “do not start the queue on device start <=> stop it right at device start”
I was actually using your scenario C as a workaround currently, but scenario A looks promising ! For some reason, I thought that if deferred start didn’t work, rte_eth_rx_queue_stop would not work either.
