I was trying the dpdk-test-regex and it complains about no devices.
Do I need to manually connect to the Regex engine or something?
Make sure the RegEx engine is active:
systemctl status mlx-regex
If the status is inactive (Active: failed), run:
systemctl start mlx-regex
enable RegEx offloading on the host, run:
host> sudo /etc/init.d/openibd stop host> sudo echo 1024 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
Then enable host access to the RegEx engine on the DPU:
dpu> echo 1 > /sys/bus/pci/devices/0000:03:00.0/regex/pf/regex_en
Output show app use VFIO driver which nvidia mlx device not build on, likely you not build DPDK correctly with NVIDIA OFED driver,
Follow below build dpdk,
https://doc.dpdk.org/guides/platform/mlx5.html#mlx5-common-compilation
Run app with -a
