Dpkg kernel error related to sysdig-dkms
Hello!
I’m getting a weird error when running anything apt install related. For example:
$ sudo apt remove aisleriot
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package 'aisleriot' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 21 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up sysdig-dkms (0.27.1-0.3ubuntu0.4) ...
Removing old sysdig-0.27.1 DKMS files...
Deleting module sysdig-0.27.1 completely from the DKMS tree.
Loading new sysdig-0.27.1 DKMS files...
Building for 5.15.136-tegra
Building initial module for 5.15.136-tegra
ERROR (dkms apport): kernel package linux-headers-5.15.136-tegra is not supported
Error! Bad return status for module build on kernel: 5.15.136-tegra (aarch64)
Consult /var/lib/dkms/sysdig/0.27.1/build/make.log for more information.
dpkg: error processing package sysdig-dkms (--configure):
 installed sysdig-dkms package post-installation script subprocess returned error exit status 10
Errors were encountered while processing:
 sysdig-dkms
E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried opening the make.log file, pasting the head and tail here given it’s over 4000 lines long. I can try a paste if you’d like the whole thing.
DKMS make.log for sysdig-0.27.1 for kernel 5.15.136-tegra (aarch64)
Sun Aug 25 05:17:40 PM PDT 2024
make: Entering directory '/usr/src/linux-headers-5.15.136-tegra-ubuntu22.04_aarch64/3rdparty/canonical/linux-jammy/kernel-source'
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/main.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/dynamic_params_table.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/fillers_table.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/flags_table.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/ppm_events.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/ppm_fillers.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/event_table.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/syscall_table.o
  CC [M]  /var/lib/dkms/sysdig/0.27.1/build/ppm_cputime.o
/var/lib/dkms/sysdig/0.27.1/build/main.c: In function ‘drop_event’:
/var/lib/dkms/sysdig/0.27.1/build/main.c:1535:17: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
 1535 |                 nanoseconds rem;
/var/lib/dkms/sysdig/0.27.1/build/syscall_table.c:60:23: error: ‘SYSCALL_TABLE_ID0’ undeclared here (not in a function); did you mean ‘SYSCALL_TABLE_SIZE’?
   60 |         [__NR_close - SYSCALL_TABLE_ID0] =                      {UF_USED | UF_NEVER_DROP | UF_SIMPLEDRIVER_KEEP, PPME_SYSCALL_CLOSE_E, PPME_SYSCALL_CLOSE_X},
      |                       SYSCALL_TABLE_SIZE
In file included from ./arch/arm64/include/uapi/asm/unistd.h:25,
                 from ./arch/arm64/include/asm/unistd.h:47,
                 from /var/lib/dkms/sysdig/0.27.1/build/syscall_table.c:22:
./include/uapi/asm-generic/unistd.h:185:20: error: array index in initializer not of integer type
 [ over 4000 lines of similar errors in code ]
/var/lib/dkms/sysdig/0.27.1/build/syscall_table.c:969:10: note: in expansion of macro ‘__NR_renameat2’
  969 |         [__NR_renameat2 - SYSCALL_TABLE_ID0] = PPM_SC_RENAMEAT2,
make[1]: *** [scripts/Makefile.build:295: /var/lib/dkms/sysdig/0.27.1/build/syscall_table.o] Error 1
make[1]: *** Waiting for unfinished jobs....
/var/lib/dkms/sysdig/0.27.1/build/main.c: In function ‘syscall_exit_probe’:
/var/lib/dkms/sysdig/0.27.1/build/main.c:2023:28: error: ‘SYSCALL_TABLE_ID0’ undeclared (first use in this function); did you mean ‘SYSCALL_TABLE_SIZE’?
 2023 |         table_index = id - SYSCALL_TABLE_ID0;
      |                            SYSCALL_TABLE_SIZE
make[1]: *** [scripts/Makefile.build:295: /var/lib/dkms/sysdig/0.27.1/build/main.o] Error 1
make[1]: *** [scripts/Makefile.build:295: /var/lib/dkms/sysdig/0.27.1/build/ppm_fillers.o] Error 1
make: *** [Makefile:1912: /var/lib/dkms/sysdig/0.27.1/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.15.136-tegra-ubuntu22.04_aarch64/3rdparty/canonical/linux-jammy/kernel-source'
Also tried to reinstall the kernel package but cant find it.
$ sudo apt-get install linux-headers-$(uname -r)
E: Unable to locate package linux-headers-5.15.136-tegra
E: Couldn't find any package by glob 'linux-headers-5.15.136-tegra'
E: Couldn't find any package by regex 'linux-headers-5.15.136-tegra'
Posting it here because I assume this is an error related to the custom install required for the Jetson. Any help appreciated!
Please check the discussion in
JetPack 5.1.1 fails to build kernel modules (with DKMS)
Yo may try to rebuild kernel without -tegra for a try. Seems like the dkms packages do not accept the suffix -tegra
