I am using Ubuntu 16.04 (JetPack 3.1) on TX1. Unfortunately I experience the following issue - after a period of inactivity the monitor goes off (as intended), but after roughly 10 seconds it turns on again completely blackened (with a mouse cursor visible).
I have experimented a lot so far:
Tried to disable gnome-screensaver (including “chmod -x /usr/bin/gnome-screensaver”)
Experimented with “xset dpms” settings and “xset s” settings
Nothing helped. The monitor just turns back on. I read about vbetool, but it’s not available on Arm64.
Any ideas/hints what to try? As it seems the problem is somewhere in X11, not in Gnome as even “xset dpms force off” doesn’t work properly.
Especially weird - after “xset s noblank; xset dpms force off” the screen turns back on with a strange grey picture.
After “xset s noexpose; xset dpms force off” the screen turns on again and shows the desktop, but after hitting a key it turns for 1-2 seconds off again and then on.
“xset s off” doesn’t help either.
I’ve also tried:
setterm -blank 5 -powersave powerdown -powerdown 5
Which resulted in:
setterm: terminal xterm-256color does not support --blank
setterm: cannot (un)set powersave mode: Inappropriate ioctl for device
Yes, monitor attached to TX1 never goes into suspend. As described it remains just black with a visible mouse cursor. I checked all possible settings, but as said - the monitor turns off for about 10 seconds as intended (after 5 minutes of inactivity), but then it just turns on again and remains black. I am using TX1 devkit + HDMI.
This command disables both screensaver and DPMS, why should I use it then? My goal is that DPMS works properly and the monitor turns off after 5 minutes of inactivity.
[ 9.212] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 9.213] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 9.213] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 9.213] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 9.213] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 9.213] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 9.213] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 9.213] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 9.213] (II) NVIDIA(0): Config Options in the README.
[ 9.275] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 9.699] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 9.699] (==) NVIDIA(0): Backing store enabled
[ 9.699] (==) NVIDIA(0): Silken mouse enabled
[ 9.720] (==) NVIDIA(0): DPMS enabled
ACPI error could theoretically lead to such misbehavior - how this could be fixed?
EDIT: installed acpid package, the error is gone, but the general misbehavior remains.
BTW, maybe it’s important to mention that I am using a monitor with 3 connected signal sources, Jetson is one of them.
