I have created an array using the following:
float *vel_h, *vel_d; // Pointers to host & device
int size = mesh_height * mesh_width * 4 * sizeof(float);
vel_h = (float *)malloc(size); // Allocate array on host
cudaMalloc((void **) &vel_d, size); // Allocate array on device
// Initialize host array and copy it to CUDA device
for (int i=0; i<mesh_width*mesh_height; i++)
vel_h[i] = (float)((rand()/((float)RAND_MAX)) * 2.0 - 1.0)*0.01f;
cudaMemcpy(vel_d, vel_h, size, cudaMemcpyHostToDevice);
is it possible to tell a direct3d/opengl device to render vertices represented by an array without copying the data back to the host and back to the device?
It would be great if i could give the IDirect3DDevice9 device the buffer pointer using SetStreamSource() method. like bellow:
// Render the vertex buffer contents
device->SetStreamSource( 0, vel_d, 0, sizeof(CUSTOMVERTEX) );
device->SetFVF( D3DFVF_CUSTOMVERTEX );
device->DrawPrimitive( D3DPT_POINTLIST, 0, num);
Again, any help would be amazing!
