I got an error that cupti.h was not found during the Tensorflow build.
nvidia@tegra-ubuntu:~/work/tf_build/tensorflow$ dpkg -L cuda-cupti-10-2
/usr
/usr/local
/usr/local/cuda-10.2
/usr/local/cuda-10.2/targets
/usr/local/cuda-10.2/targets/aarch64-linux
/usr/local/cuda-10.2/targets/aarch64-linux/lib
/usr/local/cuda-10.2/targets/aarch64-linux/lib/libcupti.so.10.2.11
/usr/local/cuda-10.2/targets/aarch64-linux/lib/libnvperf_host.so
/usr/local/cuda-10.2/targets/aarch64-linux/lib/libnvperf_target.so
/usr/share
/usr/share/doc
/usr/share/doc/cuda-cupti-10-2
/usr/share/doc/cuda-cupti-10-2/changelog.Debian.gz
/usr/share/doc/cuda-cupti-10-2/copyright
Can you please tell me how I can install cupti.h?
I wrote following version package.
SDKM : sdkmanager_1.0.1-5538_amd64.deb
DriveSoftware :10.0(rev.1)
Dear @Masayuki.Kamoda ,
Note that header files and samples of libraries are removed in DRIVE SW 10.0 to save file system space. You may check manually copying the needed header files. May I know why you are looking to install Tensorflow on DRIVE AGX? Did you check using TensorRT on DRIVE AGX to optmize your TF models?
Dear SivaRamaKrishnaNV
Thank you! Where is that file?
I use my original network.
TensorRT could not be used due to limited number of supported APIs.
I asked below question, but it is not resolved
Linux version : Ubuntu 16.04 LTS
GPU type : GeForce GTX 1080
nvidia driver version : 410.72
CUDA version : 9.0
CUDNN version : 7.0.5
Python version [if using python] : 3.5.2
Tensorflow version : tensorflow-gpu 1.9
TensorRT version : 5.0.2.6
Actual Problem,
I tried the example script under samples/python/uff_ssd folder. The Script downloads SSD_inception model, creates uff parser, builds engine and performs inference on Image.
Now, instead of downloading a pre-trained model, I trained m…
Could you check at /usr/local/cuda/include on host machine
Can we close this topic?
Yes. The build has been completed and the operation is being checked.
