DRIVE AGX Orin — nvgpu ACR bootstrap fails after reboot, NvSciBuf unusable (ACR bootstrap failed, HS ucode boot failed, err 1b)
DRIVE OS Version: 6.0.10
Error String: Provide error string encountered during your run
Issue Description: After a routine reboot, the GPU firmware no longer bootstraps. Any application that needs NvSciBuf now fails at init:
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=14
NvSciBufModuleOpen failed (0x32 = NvSciError_ResourceError)
The same applications ran correctly for several days on this install before the reboot. Nothing was flashed or updated.
Kernel log
nvgpu: 17000000.ga10b  nvgpu_acr_wait_for_completion:143  [ERR] flcn-1: HS ucode boot failed, err 1b
nvgpu: 17000000.ga10b  nvgpu_acr_wait_for_completion:145  [ERR] flcn-1: Mailbox-1 : 0xabcd1234
nvgpu: 17000000.ga10b  acr_report_error_to_sdl:54         [ERR] ACR register access failure
nvgpu: 17000000.ga10b  nvgpu_cic_mon_report_err_safety_services:90 [ERR] Reported err_id(0x296) to Safety_Services
nvgpu: 17000000.ga10b  nvgpu_pmu_report_bar0_pri_err_status_fusa:35 [ERR] PMU falcon bar0 timeout. status(0x0), error_type(0xc)
nvgpu: 17000000.ga10b  ga10b_bootstrap_hs_acr:73          [ERR] ACR bootstrap failed
nvgpu: 17000000.ga10b  nvgpu_acr_bootstrap_hs_acr:88      [ERR] ACR bootstrap failed
nvgpu: 17000000.ga10b  nvgpu_acr_construct_execute:111    [ERR] Bootstrap HS ACR failed
nvgpu: 17000000.ga10b  nvgpu_finalize_poweron:1080        [ERR] Failed initialization for: g->ops.acr.acr_construct_execute
nvgpu: 17000000.ga10b  gk20a_power_write:110              [ERR] power_node_write failed at busy
nvgpu: 17000000.ga10b  nvgpu_cic_mon_init:75              [ERR] Err inj callback registration failed: -22
This repeats on every attempt to open the GPU.
Dear @harshinhari702 ,
Is it ok to reflash the target? If it SW issue, it can be fixed via reflashing easily.
This forum is exclusively for developers who are part of the NVIDIA DRIVE® AGX SDK Developer Program | NVIDIA Developer . To post in the forum, please use an account associated with your corporate or university email address. This helps us ensure that the forum remains a platform for verified members of the developer program.
