Hi Masayuki.x.Kamoda,
in the pdkinstaller.log file the error shows: /bin/sh: 1: cpio: not found
So, it seems that, for a strange reason, your system does not have cpio installed that is installed by default. please try and run:
apt-get install -y cpio
and try flashing again.
Hi shayNV,
I have executed the suggested commands.
But the Flash failed again. The log will be attached to this post.
EDIT:
in the NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP.log file the log:
Tool OutPut:
USB communication failed.Check if device is in recovery
Tool OutPut to stderr:
error-boot-failed
It seems the binding was successfully done in the new logs you have uploaded.
But now, it seems you have a problem running the built-in Linux dumping tool “dmidecode” and the device managing tool “udev”(missing install of “udevadm”) tool and “bc” .
you can see it by all the “___ : command not found” messages in the sdkm.log file.
that is strange your system does not have them by default.
to install them use apt-get install
I suspect your system is corrupted, and you probably will get some more errors like that along the way.
Please consider trying and re-run the whole process again on a freshly installed computer and update here if this is resolved.
Hi shayNV,
I try to resolve the “___: command not found” message.
It may be because the setup in SDKM was done in Docker container.
