The issue of slow scp has not been clearly replicated and may occasionally occur after a device restart. The following are the system space info using df, boot logs, and flash logs when reproducing the problem.
I think it’s better to analyze based on the DriveOS version which can reproduce this issue always , although the version is not a Dzonerelease. Because most customer are developping based on the version 7.0.5 or later.
Dear @huyt1111 ,
On which DOS version you notice the issue consistently? Also, do you have any dependency on DOS version or can be upgraded to future DevZone releases?
Dear @huyt1111 ,
I believe you have other support channel as DOS 7.2.4 QNX is releasesd via other channel and not supported via forum. Could you reach out to your NVIDIA representative for right support channel.
Although I have other channel but the channel can only support the software about camera. I have no other channels of the problem which may be related with HW or DOS.
This problem can also be reproduced on the DevZone release Linux 7.0.3. The reason I propose this is that if you need to reproduce the issue, it will be difficult to reproduce it on the DevZone release.
That means the “MCU data 0x…” has to nothing to do with observed scp issue.
On your machine, irrespective of DOS version, you notice the scp issue. But on QNX 7.2.4 you notice this consistenly unlike on other version you notice few times.
Please share below things.
Please share the images shared in the description again as we can’t open it.
share tcu_muxer logs from docker tcu_muxer -d /dev/ttyACM0 -m T264 -b 15 -g 16 -s /home/nvidia/ . On docker /home/nvidia should have the logs. Also, share showvoltages from aurix console.
Understood, thanks for the clarification. We will no longer focus on the “Mcu Data” prints.
Q2: On which DOS version is the SCP issue consistent?
On QNX 7.2.4, the SCP slow issue is reproducible every time. On DOS 7.0.3 and DOS 7.0.5 RC6, the SCP issue is occasional — it appears sometimes but not always.
I have not concluded that. I have asked if you are saying MCU data 0x ... is noticed even when SCP is faster on other targets.
Do you consistently see MCU data 0x... messages when SCP is slow on other DOS release as well?
Does the MCU FW version changed when you flashed with other DOS releases? Or the MCU FW version causing the the issue?
