DRIVE OS Version: 7.2.5
Issue Description:
DriveOS 7.2.5: nvdvms_server exit triggers nv_panic (sysrq crash) on every cold boot
The system had been working normally and able to reboot without issue. This symptom started occuring after a USB storage drive was attached. The drive was formatted as FAT and so it was reformatted to ext4 and mounted.
On next boot and all subsequent attempts even with the USB drive removed the system now panics on startup.
I expect that my next move is to reflash
Log FIles
tio_52_2026-10-05T11:26:51.log (41.7 KB)
tio_pci-0000:09:00.3-usb-0:1.4.4.1:1.5_2026-10-05T11:26:37.log (14.3 KB)
Environment
| Item | Value |
| Platform | DRIVE AGX Thor Developer Kit (p3960-0010) |
| DriveOS | 7.2.5.0 (Linux NSR) |
| Kernel | 6.8.12-rt-tegra |
| Guest | Ubuntu 24.04.4 LTS (VM0) |
| Notes | This unit is configured as PCIe C2C endpoint |
Seen after MCU poweron / tegrareset and after Linux reboot paths. Cold boot alone is enough.
Symptom
Guest gets through PL → kernel → early systemd and reaches basic.target. Around 10 s after kernel start:
nvdvms_server.servicereports Startednv_panic.servicestarts (“NVIDIA Triggers Kernel Panic on Critical Service Failure”)- Kernel panics via sysrq:
sysrq: Trigger a crash
Kernel panic - not syncing: sysrq triggered crash
CPU: … PID: … Comm: sh Tainted: G OE 6.8.12-rt-tegra #1
Hardware name: p3960-0010 (DT)
Call trace:
__handle_sysrq+…
write_sysrq_trigger+…
Aurix NvShell then shows SoC error (expected once the guest has panicked), e.g.:
MCU_FOH: Switched to FSI_MONITORING_STATE [SOC0]
MCU_FOH: SOC error pin is asserted [SOC0]
ERROR: MCU_ERRHANDLER: SOC error pin is asserted
SSH never comes up. Recovery is from NvShell (mcureset or poweroff / poweron). Same sequence on every retry.
Suspected mechanism
From the 7.2.5 targetfs unit files:
nvdvms_server.servicehasOnFailure=nv_panic.serviceandRestart=nonv_panic.serviceis a oneshot whoseExecStartis effectively:
echo 1 > /proc/sys/kernel/sysrq && echo c > /proc/sysrq-trigger
So this does not look like a random kernel bug. nvdvms_server fails after start, systemd runs nv_panic, and the guest crashes on purpose.
nvdvms_server is gated on /proc/device-tree/enable_pm_server (present here).
Other failures on the same boot (probably not the trigger)
Logged in the same window:
accounts-daemon.serviceFAILEDnscd.serviceFAILEDnv_usbmounter@sda/@sdb/@sdb1FAILED (File-Stor gadget / MSR partition — expected on this kit)nv_usbmounter@sdb2OK (USB SSD mounts)
Those show up near the panic, but the unit graph points at nvdvms_server → nv_panic, not at those services.
Also present and ignored for now: cam_fsync … Failed to read generator status, LCM preinit Permission denied on /proc/device-tree/enable_lcm/status, and MCU Condor2: Failed to configure switch during eth bring-up (power-up still reports complete).
MCU power path
poweron finishes rails / VRS BIST / eth init (Power-up sequence is complete). SoC error pin asserts after guest userspace has already hit nv_panic, not during rail sequencing.
Questions
- Is
OnFailure=nv_panic.serviceonnvdvms_serverintentional for DevKit Linux guests in 7.2.5 EA? - What should we capture next to see why
nvdvms_serverexits? Journal is lost whennv_panicruns. Is there a supported way to disable or softennv_panicfor bring-up short ofsystemd.mask=on the cmdline? - Any known issues linking
nvdvms_serverfailure to PCIe C2C endpoint role, USB mass-storage attach, or LCM /enable_pm_serveron Thor DevKit?
Minimal repro
- Power-cycle a Thor DevKit on DriveOS 7.2.5 (NvShell
poweronor equivalent). - Watch the VM0 console through systemd.
- See
nvdvms_serverstart, thennv_panic/ sysrq crash at ~10 s. - Confirm NvShell
SOC error pin is asserted.
Full MCU + VM0 console logs attached above.
