Software Version: DRIVE OS 7.2.5
Target OS: Linux
Hardware Platform: DRIVE AGX Thor p3960-10-sw03
Kernel: 6.8.12-rt-tegra (PREEMPT_RT, built Jun 24 2026)
Issue description:
I need to read and write CAN frames on a vehicle OEM bus from Linux using the
DriveWorks CAN sensor (protocol=can.socket). The bus is wired to VH1 / DB9
connector P9 (HARNESS_CAN1 / HARNESS_CAN2, per the DRIVE AGX Thor Mechanical
and Installation Guide, DI-12070-001_v1.3, Interface Connectors table).
On the target, no CAN interface exists:
$ ip link show | grep -i can
(no output)
I loaded the stack manually:
$ sudo modprobe can
$ sudo modprobe can-raw
$ sudo modprobe can-dev
$ sudo modprobe mttcan
dmesg shows only “can: controller area network core”, "NET: Registered PF_CAN
protocol family", “can: raw protocol”, “CAN device driver interface”.
mttcan produces no probe messages.
$ lsmod | grep -i mttcan
mttcan 53248 0
can_dev 40960 1 mttcan
nvpps 32768 2 mttcan,nvethernet
$ ls /sys/bus/platform/drivers | grep -i can
mttcan
$ ls /sys/bus/platform/devices | grep -i can
(empty)
$ find /proc/device-tree -iname “*can*”
(empty)
So the mttcan driver is registered but no matching device exists in this
VM’s device tree.
What I found in the documentation and forum:
DriveOS Linux SDK 7.2.5, “CAN Driver”: "On Thor, all four CAN controllers
are in the FSI, and the FSI CAN interfaces are not visible on Linux systems."
and “Linux TegraCAN is applicable to Orin only.”
Forum topics “No canX devices/interfaces” and "Data communication modes from
MCU to SOC": on Thor there is no CAN in the CCPLEX, so SocketCAN is not
supported; FSI CAN is dedicated to safety-critical communication.
SDK “SoC to MCU Communication”: the Common Interface covers reset, boot
chain, firmware and network configuration, but does not list CAN data.
Questions:
Is there any supported way for a Linux application on Thor (DriveWorks
can.socket or plain SocketCAN) to send and receive on the CAN lines of
VH1 P9?
Where do HARNESS_CAN1 / HARNESS_CAN2 on VH1 P9 terminate on Thor: sMCU
(RH850), FSI, or elsewhere?
Does the sMCU firmware (AFW) offer any CAN gateway to the SoC (SOME/IP,
UDP, or other)? The forum says no mechanism exists for arbitrary data; is
that still true for current AFW versions?
Is FSI CAN usable from Linux once the FSI Integration Guide / DRIVE OS PDK
is available, and how would frames reach a Linux application?
Is a USB-CAN adapter (gs_usb / PEAK) the recommended approach for Linux
applications on Thor? If so, are these drivers expected in the DriveOS
Linux kernel config?
The DriveWorks CAN tutorial (“Receiving and Sending Data”) and CAN Bus
module pages in the 7.2.5 SDK still describe can.socket with device=can0.
Could the documentation note that this does not apply to Thor?
Thank you.
Title: DRIVE AGX Thor: how to access VH1 P9 CAN1/CAN2 (OEM bus) from Linux / DriveWorks? No canX, mttcan finds no device
Software Version: DRIVE OS [7.x.x.x – fill in: cat /etc/nvidia/version-ubuntu-rootfs.txt]
Target OS: Linux
Hardware Platform: DRIVE AGX Thor [fill in exact kit/SKU]; /proc/device-tree/model reports “p3960-0010”
SDK Manager Version: [fill in]
Host Machine Version: [fill in]
MCU AFW: [fill in: run “version” on the sMCU console]
Issue description:
(no output)
$ sudo modprobe can
dmesg shows only “can: controller area network core”, “NET: Registered PF_CAN
protocol family”, “can: raw protocol”, “CAN device driver interface”.
mttcan 53248 0
mttcan
(empty)
(empty)
VM’s device tree.
- DriveOS Linux SDK 7.2.5, “CAN Driver”: “On Thor, all four CAN controllers
are in the FSI, and the FSI CAN interfaces are not visible on Linux systems.”
and “Linux TegraCAN is applicable to Orin only.” - Forum topics “No canX devices/interfaces” and “Data communication modes from
MCU to SOC”: on Thor there is no CAN in the CCPLEX, so SocketCAN is not
supported; FSI CAN is dedicated to safety-critical communication. - SDK “SoC to MCU Communication”: the Common Interface covers reset, boot
Questions:
VH1 P9? -
(RH850), FSI, or elsewhere? -
that still true for current AFW versions? -
is available, and how would frames reach a Linux application? -
Linux kernel config? -
Thank you.
