DRIVE AGX THOR: how to control fan speed with automated temperature threshold system control
DRIVE OS Version: 7.0.3
Error String:
Issue Description: I would like to control the DRIVE AGX Thor fan speed according to the temperature settings or power state to reduce the noise it generates, currently i only have the following commands and i’m unable to re-flash the Thor as my membership for the DRIVE OS developers has been rejected, i was wondering if there was some way with the commands i have to set varying fan speeds based on the temperature to prevent damage due to overheating.
help : Shows all available commands supported
version : Show the current flashed/runing firmware version
mods : Set “MODS” mode
setphymdiomuxsel [0|1]: Control PHY MDIO MUX selection (0=SMCU, 1=Tegra)
getphymdiomuxsel : Display current PHY MDIO MUX selection
setuartbaudrate : Set UART Baud Rate
showport : Show the state of [P/AP]x.y
setport : Set the state of [P/AP]x.y
configport : configure the port pin [P/AP]x.y
reset : reset the system
aurixreset : alias for reset
poweron : Poweron
poweroff : Poweroff
tegrarecovery : tegrarecovery
tegrareset : tegrareset
gpio : gpio funcion
spiwrite : Write n data using master spi module x
spiread : Read n data using master spi module x
showpmic : Show the value of PMIC registers
mdio22 : mdio22 read|write address register [va]
mdio45i : mdio45i read|write address register [va]
pktcounter : access rx/tx packet counters and reset them
condor1 : condor1 read| write register [val]
condor2 : condor2 read| write register [val]
phy : access phy register
fir : access fir switch register
jasper : access jasper register
addrfilter : Packet Filter based on SA/DA
inforom : display inforom contents
setdfltbtchain [x1|x2] [A|B|C|D]: Set default boot chain configuration for Tegra x1/x2 to A|B|C|D.
getdfltbtchain [x1|x2] : Get default boot chain configuration for Tegra x1/x2.
setnxtbtchain [x1|x2] [A|B|C|D]: Set next boot chain for Tegra x1/x2 to A|B|C|D.
getnxtbtchain [x1|x2] : Get next boot chain configuration for x1/x2.
getactivebtchain [x1|x2] : Get active boot chain configuration for x1/x2.
oldshowvoltages : Show ADC Voltages
pgoodstatus : Show PGOOD status
vrs10 : VRS10 status command
vrs11 : VRS11 status command
vrs12 : VRS12 status command
canenable : enables particular CAN controller
candisable : disables particular CAN controller
cansetbr : set baudrate for particular CAN controller
cansendcyclic : Enable cyclic msg of a CAN controller
canstopcyclic : Disable cyclic msg of a CAN controller
cansendmsg : Send one shot msg
canrxprintenable : Print incoming Rx msgs
canrxprintdisable : Stops printing Rx msgs
linwrite : Send LIN frame Header and response
linread : Send LIN frame Header and receive response from slave
frwupinit : Initialize FlexRay for wakeup
frsendwup : Send FlexRay wakeup pattern
showfan : show the RPM of fans
setfan : set Duty cycle for fan x
startmcuflashing : start MCU Flashing sequence
hwpropprgseed : send seed to unlock hw prop programming
hwpropprgkey : [key] receive key to unlock hw prop programming
hwpropstatus : Status of active region of Hw Property Area
i2cread : Read data from I2C device
i2cwrite : Write data to I2C device
i2cscan : Scan i2C bus for available devices
ping : Pings the destination
switchfwtobackside [ack] : Switch the Fw to Back Side
getflashedarea [front|back] : Get the flashed area details
setbtchnsel [gpio|marker] : Set bootchain selection mode
getbtchnsel : Get the current bootchain selection mode
exitsc7 : Exit SC7 sleep
entersc7 : Enter SC7 sleep
set_sc7level : Change SC7 sleep level
set_mpfdti : Set EOT Wakeup Timer value in seconds
standby_mcu : Command used to switch off the MCU and wake it after wakeup timer runs out
Dear @iduopama-obomanu1 ,
Could you check private message?
To set fan speed, check set_fanpwm command in aurix. Please see Drive thor fan
Access to Devzone is enabled. Please check.
