DRIVE AGX Thor Power Supply Specification
DRIVE OS Version: 7.0.3
Issue Description: We have recently ordered the NVIDIA DRIVE AGX Thor Developer Kit, SKU12 In-vehicle GA version (Box). We noticed that the kit does not come with its own power supply cable or power supply unit.
Could you provide us details regarding the Thor expected power supply specification ? voltage, wattage, amperage, etc. Do we have to connect to both Thor Power Supply 12pin connector or only to 1 of them ?
We have also ordered a separate Power Supply from Thermaltake (1200W Thermaltake GF A3 GEN) but before connecting it would be great if you confirm the Thor power requirements.
Thank you in advance for your support!
FYI: @ulrich.koerber
Best Regards,
Dobrin Zainea
Dear @dobrin.zainea ,
Could please check the attached document for reference and let us know if any info is needed( to be added)?
DC Power Connector.pdf (485.4 KB)
Dear @SivaRamaKrishnaNV
Thank you so much for your prompt reply. I have checked the documentation and it seems clear how to connect to the vehicle.
Another question: Do I need to connect both power supply ports or only 1x is enough?
For example, I want to use the kit on my desk and I already have 1x PSU with 1 connector (12pins) matching one of the ports of the THOR ECU.
In case the second power supply port is required, do you have a recommendation for a split cable ?(e.g. on Thor side 1x connector with 12pins and on PSU side 2x connectors with 6 pins)
Thank you in advance for your answer!
It can boot even with single port.
If their wire can handle 30A. It should be okay. 30A x 12V = 360W(350 W is system specific). Using 2 ports allows to get more current.
Please see the discussion at How to supply power to SKU 12? if it helps.
Thank you for the information. You can consider the topic closed here.
