DRIVE Installer failed with status 140
Dear @SivaRamaKrishnaNV
I checked running poweroff and poweron commands on aurix terminal with some gap (like ~20sec ).
I got this information. And, I still can’t access Tegra A via dev/ttyACM0.
NvShell>poweroff
Info: Executing cmd: poweroff, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Powering off
INFO: MCU_PLTFPWRMGR: DL Ready drive to LOW !
INFO: MCU_PLTFPWRMGR: Orin TMON disable ....
INFO: MCU_PLTFPWRMGR: Board TMON disable ....
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring disable ....
ERROR: MCU_PLTFPWRMGR: Request VMON Power-down sequence verification failed ....Continue sequence !
INFO: MCU_PLTFPWRMGR: Power down sequence is complete !
Command Executed
MCU_FOH: MCU FOH : Power state notification for Orin power off
poweron
Info: Executing cmd: poweron, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Powering up
ERROR: MCU_PLTFPWRMGR: Enable Pre-regulator Request failed ....Move to error state !
@hongjiang.rao Please try to power reset the system with the power switch on your orin system, connect USB cable, and then send below commands via aurix console and linux shell respectively in sequence and provide the outpus for our information.
NvShell> tegrareset x1 h
$ lsusb -d 0955:
NvShell> tegrarecovery x1 on
$ lsusb -d 0955:
Please also refer to below in DRIVE OS 6.0.5 Linux Release Notes and see if it helps with your issue.
I run those commands and get these outputs:
NvShell>tegrareset x1 h
Info: Executing cmd: tegrareset, argc: 2, args: x1 h
NvShell>INFO: MCU_PLTFPWRMGR: Reseting
MCU_FOH: MCU FOH : Power state notification for Orin reset
INFO: MCU_PLTFPWRMGR: Tegra reset trigger is complete !
Command Executed
MCU_FOH: MCU FOH : Power state notification for Orin Power On
MCU_FOH: Spi Transmit Started
MCU_FOH: SPI : E2E_P05Check Status : 7 : 0
ERROR: MCU_ERRHANDLER: McuFoh E2E Frame Error
$ lsusb -d 0955:
Bus 001 Device 036: ID 0955:7045 NVidia Corp.
NvShell>tegrarecovery x1 on
Info: Executing cmd: tegrarecovery, argc: 2, args: x1 on
Command Executed
Info: Executing cmd: tegrareset, argc: 1, args: x1
INFO: BtChn_Cfg: No valid next bootchain loaded
INFO: NVMCU_ORINPWRCTRL: Tegra x1 Boot Chain: A
Command Executed
$ lsusb -d 0955:
I’ve tried using other usb-c cables and usb ports but it didn’t help.
@hongjiang.rao
Have you tried power-cycle and followed the known issue? Please note you don’t need to use the commands in the Aurix console open to put the system in reset, and in fact, can NOT have the Aurix console open at all; the flash.sh command inside uses bootburn -x option which automatically does this, but if the Aurix console is open will fail with the error seen.
Also, please refer to DRIVE Platform Supported Boards and tell us which board variant is yours.
Dear @VickNV
Yes, I have tried power-cycle and using other usb-c cables and usb ports. And, every time I run ./flash.sh, I exit the minicom connected to Aurix console or never run it. My board variant is p3710-10-s05.
Dear @hongjiang.rao,
Just want to confirm if it means you have disconnected power connections and reconnected instead of running poweron/off command from aurix. Please check trying this couple of times and if it improves.
Also, were you able to flash DRIVE OS 6.0.4 or you notice same issue?
@SivaRamaKrishnaNV
I did disconnect power connections and reconnect instead of running poweron/off command from aurix. I also tried to flash DRIVE OS 6.0.4 but it still didn’t work. At the same time, I also tried to use SDK manager on ubuntu 20.04 to flash, but it got the same error. This is the log of SDK manager.
driveinstaller.log (245.6 KB)
Have you ever closed the minicom?
Hi @distant1219
Every time I run ./flash.sh, I exit the minicom connected to Aurix console or never run it. When I tried to use SDK manager on ubuntu 20.04 to flash, the minicom was not been installed on ubuntu 20.04. So, I think the error has nothing to do with the minicom.
And I have only used minicom to connect to Aurxi console.
@hongjiang.rao have you tried USB 2.0 port mentioned?
It looks like the board is not going into recovery mode.
When did you receive this board? From the discussion, As I understand, your team just unboxed the board and notice this issue from beginning. Is it correct?
Please check again the below commands and share output
  • Connect to aurix console using sudo minicom -D /dev/ttyACM1 from host and press ENTER to get aurix console. Run tegrarecovery x1 off and tegrareset x1 on aurix console. Share the aurix console output.
  • Open new terminal on host, run lsusb and share the log output.
  • Now on aurix console, run tegrarecovery x1 on and tegrareset x1. Share aurix console log.
  • On host terminal, run lsusb and share log. We expect to see an extra NVIDIA device.
We need to bring back board into normal mode before attempting any flashing.
We notice, similar issue like board is not getting to recovery mode was fixed by couple power on/off cycles from aurix and manual power disconnection/connection to devkit.
Dear @SivaRamaKrishnaNV @VickNV
We have contacted the agent to come and inspect and the board has now been brought back for further inspection. And thank you for answering our previous questions.
Thank you for update. Please let us know the status after inspection.
@hongjiang.rao
Please help double confirm that you used the correct port (the left USB Type-C port below) for the previous tries.
Could you provide any update on previous suggestion?
I haven’t received any useful information yet, I will reply once there is a result.
Supposed this is no longer an issue to support, I’m closing it now.
If still has issue, please help to open a new topic. Thanks
