Drive orin cannot connect to the physical screen anymore
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Everthing is fine before, I can connect to my physical screen and i can use VENC too.
The last thing I do is to install pip and build-essential on Orin (bcause i found out that there is no g++ on the board), and then when i wokeup the screen, i cannot type anything to login and then I rebooted the target system. Since then i cannot connect to the monitor anymore, the monitor just doesnt receive DP signal from the device.
As you can see, after reboot, it just show small resolution background picture and then my monitor lose DP signal from the device.
I not sure if its the problem of VENC configuration, but I already restored the configuration according to the tutorial.
Dear @rlu1,
Is it ok to reflash the target to fix the issue if it is related to SW or system state? Also, consider flashing latest release DRIVE OS 6.0.10 if you don’t have any dependencies on DRIVE OS version.
I meant it’s really not a problem to do the reflash. But at least one can find an reason for it. Is it the problem for X11?
I meant the documentation almost doesnt have any information on how Orin is connected to the display.
