Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
The drive orin cannot be started after flashing, and the DP has no output
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyACM1, 16:47:04
Press CTRL-A Z for help on special keys
*************** NvShell Initialization Start******************
DRIVE-V6.0.5-P3710-AFW-Aurix-StepB-5.06.05
Compilation date: Oct 19 2022, 01:12:33
Enter 'help' to see the available commands.
*************** NvShell Initialized *************************
Press 'Enter' for NvShell prompt
MCU_FOH: E2E Initialized
MCU_FOH: Initialization done
INFO: MCU_PLTFPWRMGR: Power-on Triggered...
INFO: NvMCU_OrinTMON: toggle check of local and remote sensor successfull
Check for VRS10...
Check for VRS10...
Check for VRS11-1...
Check for VRS11-2...
Check for VRS10...
Check for VRS10...
Check for VRS10...
Check for VRS10...
INFO: NvMCU_OrinTMON: Orin Temperature sensor initialized
INFO: NVMCU_ORINPWRCTRL: FUNC_NIRQ continuous monitoring Enabled...!
INFO: NVMCU_ORINPWRCTRL: Tegra x1 Boot Chain: A
INFO: SftyMon_tmon: Board Temperature sensor initialized
INFO: MCU_PLTFPWRMGR: Board TMON enabled ....
INFO: MCU_PltfPwrMgr: Linkup status is not active
INFO: MCU_PltfPwrMgr: 88Q5072 OAK Link Active
INFO: MCU_PLTFPWRMGR: Orin TMON enabled ....
MCU_FOH: MCU FOH : Initiate SOC Error Pin Monitoring & SPI communication
INFO: Marvell Switch: p3710_oak_init
INFO: Marvell Switch: Device ID in the Spruce slave address 0x8 is not as expected
INFO: Marvell Switch: Expected 0xf130/0xf131/0xf132/0xf133, but reading back 0xa722
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x3
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x1
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x0
INFO: Marvell Switch: Port restrictions for Aurix port(P8) enabled
INFO: Marvell Switch: p3710_spruce_init
INFO: Marvell Switch: Spruce device with chip revision B4 detected on SMI address 0x1.
INFO: MCU_PltfPwrMgr: Switch Init
INFO: Marvell Phy: Initial 88Q2112 config
INFO: Marvell Phy:
Start init 88Q222x slave address 1 at group 1
INFO: Marvell Phy: Apply Legacy mode
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 1 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 2 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 2 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 3 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 3 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 4 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 4 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 5 at group 1
MCU_FOH: SOC error pin is asserted
MCU_FOH: SOC error pin is de-asserted
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 5 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 6 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 6 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 7 at group 1
MCU_FOH: Spi Transmit Started
MCU_FOH: ErrReport: ErrorCode-0x1012 ReporterId-0xe00e Error_Attribute-0x0 Timestamp-0x6194187
MCU_FOH: ErrReport: ErrorCode-0x89abcdef ReporterId-0x8013 Error_Attribute-0x0 Timestamp-0x6195417
MCU_FOH: Periodic Report: KeyOfSeed-0xffff
MCU_FOH: Periodic Report[0]:SystemFailureId-0xabcd, MaturationState-0xef, Failure_Attribute-0x22
MCU_FOH: Periodic Report[9]:SystemFailureId-0x1234, MaturationState-0x56, Failure_Attribute-0xee
MCU_FOH: ErrReport: ErrorCode-0x28c7 ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x948722f
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 7 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 1 at group 0
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 1 at group 0, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 2 at group 0
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 100M, slave address 2 at group 0, API 1.10
INFO: MCU_PltfPwrMgr: PHYs Init
INFO: MCU_PltfPwrMgr: StbM Init
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !
INFO: MCU_PLTFPWRMGR: DL Ready drive to HIGH !
Power on the system
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started...
INFO: MCU_SWC_FanControl: max_rpm fan2 : 0
INFO: MCU_SWC_FanControl: maxrpm of fan2 has more than 50 percent deviation against rated maxrpm
ERROR: MCU_SWC_FanControl: count_NoEthFrame expired
ERROR: MCU_SWC_FanControl: count_NoEthFrame_TA value reached to: 101
ERROR: MCU_SWC_FanControl: moving to error state
