DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux not found after installation from SDK Manager
Dear @ai.trucker,
I meant to use DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux directory path for /path/to/drive-t186ref-linux in the command
Do you mean to say use /my/home/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux in the compilation command of the drive works samples ?
Dear @ai.trucker,
Please use /my/home/nvidia/nvidia_sdk/ /DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux in DW compilation command. Note /my/home refers to your $HOME directory
I tried to reinstall DOS and DW again from SDK Manager and in the process I might have messed up my previous cuda install (I was trying sudo apt-get purge cuda*) . I do not have /usr/local/cuda* anymore.
When I try to reinstall - I run into error for “sudo apt --fix-broken install”.
Screen Shot 2021-09-21 at 1.23.31 AM
I need to get cuda installation back, as there is no /usr/local/cuda*.
I looked that quite a few old issues related to ‘sudo apt --fix-broken install’ from SDK manager - These links - a) firstb) second c) third - do not seem to address my issue.
Dear @ai.trucker,
What did you see when you run sudo apt --fix-broken install?
Mostly file overwrite issue. I tried moving these files out manually - but it seems to try to write these files twice and wouldn’t like it the second time !
Dear @ai.trucker,
Please check force installation using for each debian package in the error log like sudo dpkg -i --force-overwrite <debian package> . I expect this to install the require versions for the DRIVE OS 5.2.0
There were errors for debs as shown in pic. But it seem to wipe those debs out while exiting. I cannot see any /tmp/apt* directory or any debian package.
Please check force installing the debian packages from the DRIVE OS 5.2.0 download folder manually. Let us know how it goes.
I do not see them in download folder -
~/Downloads/nvidia/sdkm_downloads$ sudo dpkg -i --force-overwrite cuda-nvcc-cross-aarch64-10-2_10.2.311-1_all.deb
dpkg: error: cannot access archive 'cuda-nvcc-cross-aarch64-10-2_10.2.311-1_all.deb': No such file or directory
~/Downloads/nvidia/sdkm_downloads$ ls cuda-nvcc*
ls: cannot access 'cuda-nvcc*': No such file or directory
Dear @ai.trucker,
DRIVE OS 5.2.0 has CUDA 10.2.187. So check installing 10.2.187 debians. Please double check the used sdkm download folder when installing the DRIVE OS 5.2.0.
Is there another way to download ? If you see above msg, I am looking for cuda-nvcc* (for any version) - but I cannot find any, in ~/Downloads/nvidia/sdkm_downloads folder.
Dear @ai.trucker,
Could you share the content of ~/Downloads/nvidia/sdkm_downloads ?
Please find it attached.
Thanks.junk (11.1 KB)
Dear @ai.trucker,
Please use cuda-repo-ubuntu1804-10-2-local-10.2.187-440.101_1.0-1_amd64.deb to install CUDA on host
Thanks SivaRamaKrishnaNV. I have not been able to solve this. I will reinstall SDK Manager, DW and try it again.
