System Environment:
Hardware: NVIDIA DRIVE AGX Orin
Sensors: 4x AR0820 (8MP) via MAX96712 Deserializer (Group A)
OS: Drive OS 6.0.4 (Linux SDK) / Ubuntu 20.04
Kernel: 5.10.104-tegra
Python: 3.8.10
PyTorch: 1.12.0a0+nv22.06 (CUDA 11.4 verified)
Objective: I am trying to run Object Detection (YOLOv8) on 4x GMSL cameras simultaneously in Python with low latency.
Current Status (What Works): I have verified the hardware and low-level drivers using the pre-compiled C++ sample nvsipl_camera. The following command works perfectly and activates all 4 cameras:
Bash
sudo /opt/nvidia/drive-linux/samples/nvmedia/nvsipl/test/camera/nvsipl_camera \
--platform-config "F008A120RM0A_CPHY_x4" \
--link-enable-masks "0x1111 0x0000 0x0000 0x0000" \
--enableRawOutput \
--showfps
The Problem: I cannot access these streams from Python to run inference. I attempted to use OpenCV with GStreamer (nvsiplsrc), but it appears GStreamer plugins for SIPL are missing or not configured in this Drive OS build.
Failing Python Code:
Python
import cv2
# Standard GStreamer pipeline for SIPL
pipeline = (
"nvsiplsrc platform-config=F008A120RM0A_CPHY_x4 selector-mask=0x0001 ! "
"video/x-raw(memory:NVMM) ! "
"nvvidconv ! video/x-raw, format=BGRx ! "
"videoconvert ! video/x-raw, format=BGR ! "
"appsink drop=1"
cap = cv2.VideoCapture(pipeline, cv2.CAP_GSTREAMER)
Error Output:
Plaintext
[ WARN:0] global ... open OpenCV | GStreamer warning: Error opening bin: no element "nvsiplsrc"
Investigation: When I try to check for the plugin, the command is not found:
Bash
cnmost@tegra-ubuntu:/$ gst-inspect-1.0
bash: gst-inspect-1.0: command not found
It seems the GStreamer SIPL integration is missing from my environment.
My Questions:
Is there a direct Python API/Binding for NvMedia/SIPL available in Drive OS 6.0 that avoids GStreamer?
If not, what is the recommended low-latency method to get frames from
nvsiplC++ drivers into a Python memory buffer (e.g. PyTorch Tensor or NumPy array)? -
Are the GStreamer plugins (
libgstnvsipl.so) supposed to be present in the standard Drive OS 6.0 docker/flash? If so, where are they located?
I am currently considering using Named Pipes (FIFO) to pipe raw YUV data from the C++ sample to Python, but I am looking for a cleaner, official solution.
Thanks for any support.
