DRIVE OS 6.0.4 root filesystem partition rw permission
Hi, expert,
I want to know how to mount the root filesytem partition permission as read-write in compile period on DRIVE OS 6.0.4. I know there is a parameter called ’ OS_ARGS_ROOT_MOUNT_PER’ in PCTs can set the root filesytem partition permission on DRIVE OS 6.0.6. But I did not find any relate on NVIDIA DRIVE OS Linux SDK Developer Guide 6.0.4 Release.
I have changed ‘virtual_storage_ivc_ch’ value to disable the write-protect on DRIVE OS 6.0.4.
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
[√] DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[√] 1.9.3.10904
other
Host Machine Version
[√] other
Dear @haomiao.wang,
Is it possible to move to the latest release?
@SivaRamaKrishnaNV Sorry, I just want to use Drive OS 6.0.4.
Dear @haomiao.wang,
Do you have issue to install any packages on target now?
@SivaRamaKrishnaNV yeah, I want to compile the image which with the rw permission of root filesytem partition on default. I know I can use the command ‘mount -o remount,rw /’ after bootup. But I do not want do that procedure. I want get a rw permission after device bootup default.
Dear @haomiao.wang,
This is not noticed in recent versions and filesystem has rw permissions. How about keeping the mount command in bashrc or startup job?
May I know the reason for sticking to DRIVE OS 6.0.4?
@SivaRamaKrishnaNV All right, It seems without any good idea. Thank you.
