Continuing the discussion from MAX96724 + OX08D10 on Thor: raw capture works at 30fps, DriveWorks stack smashes, ISP auto-control fails:
DriveWorks stack smash issue was solved by patched library so raw capture works perfectly but enabling any ISP output segfaults immediately.
On DRIVE AGX Thor / DRIVE OS 7.2.5, raw capture works perfectly but enabling any
Setup
Platform : DRIVE AGX Thor devkit (P3960)
DRIVE OS : 7.2.5.0-46229577
Kernel : 6.8.12-rt-tegra
Camera : OX08D10 + MAX96717F, 4 active exposures
Deserializer: MAX96724, CSI-GH, 4-lane CPHY
A) RAW capture works - 4 cameras, no drops
./nvsipl_camera -c OX08D10-EXAE-AA1C_CPHY_x4 -m "0x0000 0x0000 0x1111"
-0 -1 -2 -R -b 0 -Z -I -s -r 20
Sensor12_Out0 Frame rate (fps): 29.9991
Sensor13_Out0 Frame rate (fps): 29.9991
Sensor14_Out0 Frame rate (fps): 29.9991
Sensor15_Out0 Frame rate (fps): 29.9991
Sensor12 Frame captured: 597 Frame drops: 0 Frame discontinuities: 0
Sensor13 Frame captured: 597 Frame drops: 0 Frame discontinuities: 0
Sensor14 Frame captured: 597 Frame drops: 0 Frame discontinuities: 0
Sensor15 Frame captured: 597 Frame drops: 0 Frame discontinuities: 0
B) Same command with ISP enabled - segfault
./nvsipl_camera -c OX08D10-EXAE-AA1C_CPHY_x4 -m "0x0000 0x0000 0x0001"
-1 -2 -b 0 -Z -I -s -r 20
exit=139
Complete application output, all of it:
LCM state change: 2
Pipeline: 12 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
timeout: the monitored command dumped core
Kernel log for the same run - the driver reports both VI and ISP setup OK:
cam_fsync c230000.tsc_sig_gen: Group 0 found
cdi-mgr sipl_devblk_1: cdi_mgr_gpio_config: unknown gpio idx 7
tegra194-vi5 8181240000.host1x:vi1@8188c00000: [PIPELINE 12] VI capture setup complete (channel_id=0, csi_stream=5, vc=0)
tegra194-isp5 8188800000.isp: [PIPELINE 12] ISP capture setup complete (channel_id=1)
So the kernel side completes; the crash is in user space right after the ISP
output format is selected. Note the NITO is never even opened - there is no
“Opened NITO file” line before the crash.
C) Same failure offline, no camera involved
./nvsipl_reprocess -c OX08D10-EXAE-AA1C_CPHY_x4 -m "0x0000 0x0000 0x0001"
--nito /usr/share/camera/OX08D10-EXAE-AA1C.nito
-i frame.raw -f /tmp/out -n 2 --out0 yuv420_8b_pl
nvsipl_reprocess: ERROR: Register Sipl Control(NV) failed for ISP output of sensor: 12
Here it reports cleanly instead of crashing, from a RAW file, with no camera.
What we already ruled out
- NITO: 12 different files fail identically, including your stock ones
(C1O08D101DRZ0120HB1, C1O08D101DRZ0070HB1, C1O03H101ERZ0195NB1). Also tested
through DriveWorks with an explicit nito-file= override. - Plugin: --plugin NV and --plugin SAMPLE both fail (SAMPLE: status 10).
- Auto control entirely: characterization mode (-E ,0 --plugin 1) creates
its own plugin with manual exposure settings -
Created HDR mode plugin with manually set capture settings set idx [0]
and the ISP still segfaults. So this is not a NITO / plugin / auto-control
problem. - Output format: ISP0 and ISP1 (YUV420 8b BL) and ISP2 (RGBA FP16) all crash.
- Camera HAL path (-H): cannot load our config at all,
ERROR: Query GetConfig failed. status: 1
