Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10431
other
Host Machine Version
other
I used gparted to see the partitions on the disk because the manual says that the drive is 256GB, however there’s only 28GB available. I see that there are more partitions. What are they? I formatter one that is 112GB, however it’s not enough.
I want to upgrade to a larger drive. I installed a new drive (1TB), however the installation in the manager fails, I see in the log that the system goes to the configuration file with partitions configurations. How can we configure my own hard drive?
I want to replace the current m2, 256GB hard drive, with a bigger one 1TB, split partitions on it as I like and install the OS on it.
Is it possible?
I need an answer ASAP!
Thanks, waiting for the confirmed answer.
Anyway, I guess it’s possible, but not straightforward, so, I’ll be glad if you suggest how to do so. I’m sure it will help me and other developers who use this system.
Dear @NikolayChernuha,
I would like to understand why you need extra space on target? Does your use case need high speed?Could you share your use case?
