NvShell>tegrarecovery x1 off
Info: Executing cmd: tegrarecovery, argc: 2, args: x1 off
Command Executed
NvShell>tegrareset x1
Info: Executing cmd: tegrareset, argc: 1, args: x1
NvShell>INFO: MCU_PLTFPWRMGR: Reseting
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring disable.
INFO: BtChn_Cfg: No valid next bootchain loaded
INFO: NVMCU_ORINPWRCTRL: Tegra x1 Boot Chain: B
MCU_FOH: SPI : E2E_P05Check Status : 7 : 0
ERROR: MCU_ERRHANDLER: McuFoh E2E Frame Error
INFO: MCU_PLTFPWRMGR: Tegra reset trigger is complete !
Command Executed
MCU_FOH: MCU FOH : Initiate SOC Error Pin Monitoring & SPI communication
MCU_FOH: SOC error pin is de-asserted
MCU_FOH: SOC error pin is asserted
MCU_FOH: Spi Transmit Started
MCU_FOH: ErrReport: ErrorCode-0x28da ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x600c691
MCU_FOH: ErrReport: ErrorCode-0x28d1 ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x600c979
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x600cc71
MCU_FOH: ErrReport: ErrorCode-0x9 ReporterId-0x800d Error_Attribute-0x0 Timestamp-0x600d0e9
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x614c729
MCU_FOH: Periodic Report: KeyOfSeed-0xffff
MCU_FOH: Periodic Report[0]:SystemFailureId-0xabcd, MaturationState-0xef, Failure_Attribute-0x22
MCU_FOH: Periodic Report[9]:SystemFailureId-0x1234, MaturationState-0x56, Failure_Attribute-0xee
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started…
INFO : MCU_ISTMGR: IST Manager initialized to send/receive commands
INFO: MCU_SWC_FanControl: max_rpm fan2 : 0
INFO: MCU_SWC_FanControl: maxrpm of fan2 has more than 50 percent deviation against rated maxrpm
MCU_FOH: ErrReport: ErrorCode-0x18550080 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x29be1aa1
root@6.0.10.0-0009-build-linux-sdk:/drive# lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0408:30c3 Quanta Computer, Inc. USB2.0 HD UVC WebCam
Bus 003 Device 017: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
Bus 003 Device 002: ID 0b05:19b6 ASUSTek Computer, Inc. N-KEY Device
Bus 003 Device 004: ID 8087:0033 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
NvShell>tegrarecovery x1 on
Info: Executing cmd: tegrarecovery, argc: 2, args: x1 on
Command Executed
Command Executed
NvShell>MCU_FOH: SOC error pin is de-asserted
MCU_FOH: ErrReport: ErrorCode-0x28da ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x604fece
MCU_FOH: ErrReport: ErrorCode-0x28d1 ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x60501be
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x60504be
MCU_FOH: ErrReport: ErrorCode-0x9 ReporterId-0x800d Error_Attribute-0x0 Timestamp-0x6050946
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x61aab7e
Command Executed
Command Executed
MCU_FOH: ErrReport: ErrorCode-0x28da ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x6033779
MCU_FOH: ErrReport: ErrorCode-0x28d1 ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x6033a69
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x6033d61
MCU_FOH: ErrReport: ErrorCode-0x9 ReporterId-0x800d Error_Attribute-0x0 Timestamp-0x60341d1
MCU_FOH: ErrReport: ErrorCode-0x18540001 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x616dcf1
MCU_FOH: ErrReport: ErrorCode-0x18550080 ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x29bbc589
