I have configured both can0 (on Tegra A) and can1 (on Tegra B) as follow:
$ sudo apt-get install can-utils
Step 1. Connected PCAN to can-5 and can6 port.
- can-5 → can0 on Tegra A
- can-6 → can1 on Tegra B
- can-1 → channel A on Aurix
- can-2 → channel B on Aurix
- can-3 → channel C on Aurix
- can-4 → channel D on Aurix
Step2. Enable can0 on Tegra A
$sudo ip link set can0 type can bitrate 500000
$sudo ip link set can0 up
Step3. Run candump
$sudo candump can0
(Repeated the same commands with can1 to enable can 1 on Tegra B)
Can0 immediately shows CAN traffic on terminal while can1 does NOT.
Also checked details of the links with the following commands:
#ip -details -statistics link show can0
#ip -details -statistics link show can1
Comparing the configuration, both looked the same with no errors and still can1 does not show any CAN traffic.
What else could be causing this issue?
