We have a issue of DrivePX2 rebooting at high CPU load.
It occurs only in TegraA, not in TegraB.
For example, it occurs at following steps.
- step 1: Execute the command "stress -c 4".
- step 2: Click desktop icon "DriveNet(file)".
The log when the reboot occured is below.
The log is the output to HostPC from debug port on DrivePX2.
[ 809.909543] nvgpu: 0000:04:00.0 __nvgpu_check_gpu_state:60 [ERR] GPU has disappeared from bus!!
[ 809.911297] nvgpu: 0000:04:00.0 __nvgpu_check_gpu_state:61 [ERR] Rebooting system!!
Feb 17 21:59:11 tegra-ubuntu kernel: [ 809.909543] nvgpu: 0000:04:00.0 __nvgpu_check_gpu_state:60 [ERR] GPU has disappeared from bus!!
Feb 17 21:59:11 tegra-ubuntu kernel: [ 809.911297] nvgpu: 0000:04:00.0 __nvgpu_check_gpu_state:61 [ERR] Rebooting system!!
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.160396] tegra-xusb 3530000.xhci: Host not halted after 16000 microseconds.
[ 810.235001] tegradc 15220000.nvdisplay: can't set parent_clk_safe for sor->ref_clk
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.235001] tegradc 15220000.nvdisplay: can't set parent_clk_safe for sor->ref_clk
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.236982] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.247341] sdhci-tegra 3460000.sdhci: Tuning done, restoring the best tap value : 10
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.249351] therm-fan-est: shutting down
Feb 17 21:59:11 tegra-ubuntu kernel: [ 810.249592] nvgpu: 18000000.vgpu gk20a_pm_shutdown:872 [INFO] shutting down
[ 810.323950] tegradc 15200000.nvdisplay: can't set parent_clk_safe for sor->ref_clk
[ 810.327346] reboot: Restarting system
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.80-rt61-tegra (buildbrain@mobile-u64-3039) (gcc version
The software version is:
- TegraA/B : DRIVEOS 5.0.10.3
- Aurix : DRIVE-V5.0.10-P2379-EB-Aurix-With3LSS-4.02.04
We have another DrivePX2.
So we tried with the another one, but this did not happen.
Therefore we’d think this issue uniquely only with this one.
Does anyone know what causes this error and how to fix it?
