Hardware Platform: DRIVE AGX Pegasus™ Developer Kit
Software Version: DRIVE Software 10
Host Machine Version: native Ubuntu 18.04
SDK Manager Version: Example: 1.4.0.7363
GPU Hardware Architecture: Maxwell (Note: I know I cannot run applications on host machine with this)
I am having trouble installing the the CUDA-X AI Host Component. I am relatively new to Linux so I appreciate your help. Thank you!
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvinfer6-cross-aarch64 is already the newest version (6.3.1-1+cuda10.2).
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvonnxparsers6-cross-aarch64 is already the newest version (6.3.1-1+cuda10.2).
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvparsers6-cross-aarch64 is already the newest version (6.3.1-1+cuda10.2).
23:00:52 INFO: TensorRT Cross-Compile for Linux: The following packages were automatically installed and are no longer required:
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvinfer-consistency6 libnvinfer-safe6
23:00:52 INFO: TensorRT Cross-Compile for Linux: Use ‘sudo apt autoremove’ to remove them.
23:00:52 INFO: TensorRT Cross-Compile for Linux: The following NEW packages will be installed:
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvinfer-dev-cross-aarch64 libnvinfer-plugin-dev-cross-aarch64
23:00:52 INFO: TensorRT Cross-Compile for Linux: libnvonnxparsers-dev-cross-aarch64 libnvparsers-dev-cross-aarch64
23:00:53 INFO: TensorRT Cross-Compile for Linux: 0 upgraded, 4 newly installed, 0 to remove and 9 not upgraded.
23:00:53 INFO: TensorRT Cross-Compile for Linux: Need to get 0 B/45.2 MB of archives.
23:00:53 INFO: TensorRT Cross-Compile for Linux: After this operation, 239 MB of additional disk space will be used.
23:00:53 INFO: TensorRT Cross-Compile for Linux: Get:1 file:/var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724 libnvinfer-dev-cross-aarch64 6.3.1-1+cuda10.2 [43.1 MB]
23:00:53 INFO: TensorRT Cross-Compile for Linux: Get:2 file:/var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724 libnvinfer-plugin-dev-cross-aarch64 6.3.1-1+cuda10.2 [1,287 kB]
23:00:53 INFO: TensorRT Cross-Compile for Linux: Get:3 file:/var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724 libnvonnxparsers-dev-cross-aarch64 6.3.1-1+cuda10.2 [265 kB]
23:00:53 INFO: TensorRT Cross-Compile for Linux: Get:4 file:/var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724 libnvparsers-dev-cross-aarch64 6.3.1-1+cuda10.2 [538 kB]
23:00:54 INFO: TensorRT Cross-Compile for Linux: Selecting previously unselected package libnvinfer-dev-cross-aarch64.
23:00:54 INFO: TensorRT Cross-Compile for Linux: (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 302099 files and directories currently installed.)
23:00:54 INFO: TensorRT Cross-Compile for Linux: Preparing to unpack …/libnvinfer-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb …
23:00:54 INFO: TensorRT Cross-Compile for Linux: Unpacking libnvinfer-dev-cross-aarch64 (6.3.1-1+cuda10.2) …
23:00:57 INFO: TensorRT Cross-Compile for Linux: dpkg: error processing archive /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvinfer-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb (–unpack):
23:00:57 INFO: TensorRT Cross-Compile for Linux: trying to overwrite ‘/usr/lib/aarch64-linux-gnu/stubs/libnvinfer.so’, which is also in package libnvinfer5-cross-aarch64 5.1.4-1+cuda10.2
23:00:58 INFO: TensorRT Cross-Compile for Linux: Preparing to unpack …/libnvinfer-plugin-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb …
23:00:58 INFO: TensorRT Cross-Compile for Linux: Unpacking libnvinfer-plugin-dev-cross-aarch64 (6.3.1-1+cuda10.2) …
23:00:58 INFO: TensorRT Cross-Compile for Linux: dpkg: error processing archive /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvinfer-plugin-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb (–unpack):
23:00:58 INFO: TensorRT Cross-Compile for Linux: trying to overwrite ‘/usr/lib/aarch64-linux-gnu/stubs/libnvinfer_plugin.so’, which is also in package libnvinfer5-cross-aarch64 5.1.4-1+cuda10.2
23:00:58 INFO: TensorRT Cross-Compile for Linux: Preparing to unpack …/libnvonnxparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb …
23:00:58 INFO: TensorRT Cross-Compile for Linux: Unpacking libnvonnxparsers-dev-cross-aarch64 (6.3.1-1+cuda10.2) …
23:00:58 INFO: TensorRT Cross-Compile for Linux: dpkg: error processing archive /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvonnxparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb (–unpack):
23:00:58 INFO: TensorRT Cross-Compile for Linux: trying to overwrite ‘/usr/lib/aarch64-linux-gnu/stubs/libnvonnxparser.so’, which is also in package libnvinfer5-cross-aarch64 5.1.4-1+cuda10.2
23:00:58 INFO: TensorRT Cross-Compile for Linux: Preparing to unpack …/libnvparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb …
23:00:58 INFO: TensorRT Cross-Compile for Linux: Unpacking libnvparsers-dev-cross-aarch64 (6.3.1-1+cuda10.2) …
23:00:58 INFO: TensorRT Cross-Compile for Linux: dpkg: error processing archive /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb (–unpack):
23:00:58 INFO: TensorRT Cross-Compile for Linux: trying to overwrite ‘/usr/lib/aarch64-linux-gnu/stubs/libnvparsers.so’, which is also in package libnvinfer5-cross-aarch64 5.1.4-1+cuda10.2
23:00:58 ERROR: TensorRT Cross-Compile for Linux: No apport report written because MaxReports is reached already
23:00:58 INFO: TensorRT Cross-Compile for Linux: Errors were encountered while processing:
23:00:58 INFO: TensorRT Cross-Compile for Linux: /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvinfer-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb
23:00:58 INFO: TensorRT Cross-Compile for Linux: /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvinfer-plugin-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb
23:00:58 INFO: TensorRT Cross-Compile for Linux: /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvonnxparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb
23:00:58 INFO: TensorRT Cross-Compile for Linux: /var/nv-tensorrt-repo-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724/./libnvparsers-dev-cross-aarch64_6.3.1-1+cuda10.2_all.deb
23:01:00 ERROR: TensorRT Cross-Compile for Linux: E
23:01:00 ERROR: TensorRT Cross-Compile for Linux: : Sub-process /usr/bin/dpkg returned an error code (1)
23:01:00 INFO: TensorRT Cross-Compile for Linux: [ Package Install Finished with Error ]
23:01:00 INFO: TensorRT Cross-Compile for Linux: [host] [ 74.36 MB used. Disk Avail: 144.23 GB ]
23:01:00 INFO: TensorRT Cross-Compile for Linux: [ NV_TENSORRT_HOST_CROSS_LINUX_COMP Install took 13s ]
23:01:00 ERROR: TensorRT Cross-Compile for Linux: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install libnvinfer6-cross-aarch64=6.3* libnvinfer-dev-cross-aarch64=6.3* libnvinfer-plugin6-cross-aarch64=6.3* libnvinfer-plugin-dev-cross-aarch64=6.3* libnvonnxparsers6-cross-aarch64=6.3* libnvonnxparsers-dev-cross-aarch64=6.3* libnvparsers6-cross-aarch64=6.3* libnvparsers-dev-cross-aarch64=6.3* ; [error]: exit status 100; [deb_path]: /home/user1/Downloads/nvidia/sdkm_downloads/nv-tensorrt-repo-ubuntu1804-cuda10.2-trt6.3.1.3-d5l-cross-ga-20200724_1-1_amd64.deb
23:01:00 ERROR: TensorRT Cross-Compile for Linux: command terminated with error
23:01:00 SUMMARY: TensorRT Cross-Compile for Linux: Failed to install debian repository file [host]
