Having issues to install Drive Software Plarform with SDK Manager. Getting the following error :
16:20:52 INFO : Drive Platform Targetfs : docker: Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers).
16:20:52 INFO : Drive Platform Targetfs : See ‘docker run --help’.
16:20:52 INFO : Drive Platform Targetfs : ERROR: Running hello-world container failed
16:20:52 INFO : Drive Platform Targetfs : Time to run prerequisite script: 2 minutes and 37 seconds
16:20:52 INFO : Drive Platform Targetfs : INFO: Starting installation step for avrfs
16:20:52 INFO : Drive Platform Targetfs : INFO: Installing all of the components
16:20:52 INFO : Drive Platform Targetfs : INFO: Building docker image.
16:20:52 INFO : Drive Platform Targetfs : Sending build context to Docker daemon 54.09kB
16:20:52 INFO : Drive Platform Targetfs : Step 1/4 : FROM ubuntu:18.04
16:21:07 INFO : Drive Platform Targetfs : Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
16:21:07 INFO : Drive Platform Targetfs : ERROR: could not build docker image
16:21:07 INFO : Drive Platform Targetfs : INFO: Removing the docker image(s) that was just created
16:21:08 INFO : Drive Platform Targetfs : Total reclaimed space: 0B
16:21:08 INFO : Drive Platform Targetfs : ERROR: The docker failed to properly install the components
16:21:08 INFO : Drive Platform Targetfs : Time to failure: 2 minutes and 53 seconds
16:21:08 INFO : Drive Platform Targetfs : exit status 1
16:21:08 INFO : Drive Platform Targetfs : [ Package Install Finished with Error ]
16:21:08 INFO : Drive Platform Targetfs : [ 401.90 MB used. Disk Avail: 2361.99 GB ]
16:21:08 INFO : Drive Platform Targetfs : [ NV_DRIVE_PLATFORM_RFS_TARGET_COMP Install took 2m56s ]
16:21:08 ERROR : Drive Platform Targetfs : Run commands failed at step Install: command /tmp/tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh finished with error
Has anyone else encountered this error with SDK Manager ?
