Hi VickNV,
In my Ubuntu 20.04.5 host, a physical PC, 0955:xxxx is outputed in lsusb command, but still failed to enter recovery mode. I even tried tegrarecovery & tegrareset commands and then run bootburn.py immediately. But still got the same error:
yang@xps:~/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn$ lsusb | grep 0955
Bus 001 Device 011: ID 0955:7045 NVIDIA Corp.
yang@xps:~/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn$ ./bootburn.py -b p3710-10-s05 -B qspi
****** Starting bootburn/bootburn.py ********
Script directory: /home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn
Parent directory added to path: /home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/..
********* Starting t23x bootburn py ********
Bootburn Starting with arguments ['./bootburn.py', '-b', 'p3710-10-s05', '-B', 'qspi']
cwd in setBoardConfigPath :: /home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn_t23x_py
trying hardware folder:
/home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/platform-config/hardware/nvidia/platform/t23x/automotive/flashing/board_configs
cwd in loadBoardGoldenRegsFile :: /home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn_t23x_py
Default Schema:/home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn_t23x_py/nv-customer-data-schema-orin.json
Check finished successfully
Done parsing command line
[bootburn]: [getListTargetsInRecovery(3508)] : Bus 001 Device 011: ID 0955:7045 NVIDIA Corp.
[bootburn]: [CheckRecoveryTargets(3466)] : No recovery-target found; Make sure the target device is connected to the
[bootburn]: [CheckRecoveryTargets(3467)] : host and is in recovery mode. Exiting
command line used was:
ERROR_TARGET_RECOVERY
Exception caught in bootburn
File "/home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn.py", line 288, in bootburn
bootburnLib.CheckRecoveryTargets()
File "/home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn_lib.py", line 3468, in CheckRecoveryTargets
AbnormalTermination("ERROR_TARGET_RECOVERY", nverror.NvError_ResourceError)
File "/home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/flashtools_nverror.py", line 249, in AbnormalTermination
raise OSError(errorCode)
OSError: 15
returning to directory /home/yang/nvidia/nvidia_sdk/DRIVE_OS_6.0.4_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-foundation/tools/flashtools/bootburn
Cleaning up ...
Cleaning temp dir
