DRIVEOS 7.2.5 AGX Thor P3960: OX03H10-EXAE-BA0C DriveWorks camera.gmsl fails in parseCSIPortMapInfo due to missing des_tx_port while NvSIPL works
DRIVE OS Version:
Platform
  • NVIDIA DRIVE AGX Thor P3960
  • DRIVE OS 7.2.5
  • Target OS: Ubuntu 24.04.4 LTS
  • Kernel: 6.8.12-rt-tegra
  • Camera: OX03H10-EXAE-BA0C, 3 MP
  • Deserializer: MAX96724
  • DriveWorks: 7.2 (libdw_sensors_std.so.7.2)
Error String: Provide error text encountered during your run
Issue Description:
Issue
We are trying to initialize an OX03H10 camera from DriveWorks using camera.gmsl.
The physical camera and NvSIPL configuration work correctly. For example, on CSI-AB/link 0:
NVSipl Command:
sudo ./nvsipl_camera \
-c OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 \
–link-enable-masks ‘0x1000 0x0000 0x0000’ \
–disableISP0Output \
–disableISP1Output \
–disableISP2Output \
–enableRawOutput \
–showfps \
–runfor 5 \
-v2
The camera initializes and streams at approximately:
 Sensor3_Out0 Frame rate: 29.9991 fps
We have also successfully tested four OX03H10 cameras simultaneously with NvSIPL using both the x2 and x4 platform configurations. All four stream at approximately 30 FPS with zero frame drops.
However, the equivalent DriveWorks rig fails.
Rig.json:
“name”: “camera:front:rooftop:left”,
“parameter”: “camera-name=OX03H10-EXAE-BA0C_MAX96724,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1,nito-file=/usr/share/camera/OX03H10-EXAE-BA0C.nito”,
“protocol”: “camera.gmsl”
Previously on DriveOS 7.0.3, the below rig worked on the thor:
"rig": {
    "sensors": \[
            "name": "camera:front:center:ox03h10",
            "nominalSensor2Rig_FLU": {
                "roll-pitch-yaw": \[
                    0.0,
                    0.0,
                    0.0
                "t": \[
                    1.8621,
                    -0.1939,
                    1.3165
            "parameter": "camera-name=OX03H10-EXAE-BA0C_R1E_H,deserializer=MAX96712_Fusa_nv,disable-custintf=1,groupInit=1,interface=csi-ef,CPHY-mode=1,link=2,output-format=processed,skip-eeprom=1,async-record=1,file-buffer-size=16777216",
            "properties": {
                "Model": "pinhole",
                "width": "3840",
                "height": "2160",
                "cx": "1920",
                "cy": "1080",
                "fx": "2000",
                "fy": "2000",
                "k1": "0.0",
                "k2": "0.0",
                "k3": "0.0",
                "polynomial-type": "backward"
            "protocol": "camera.gmsl"
    "vehicle": {
        "valid": false
"version": 6
Testing Command:
sudo /usr/local/driveworks/tools/sensors/sensor_initializer \
–rig=/opt/sw-constr/Configs/Rig/rig_3mp_csi_ab_link0.json \
–offscreen=1
DriveWorks correctly identifies:
  • Platform: Detected Drive Thor P3960
  • devBlock: 0 Passive = 0
  • Interface = csi-ab
  • Camera_name = OX03H10-EXAE-BA0C_MAX96724_CPHY_x4
  • Link = 0
  • Found matching DeviceBlock with csiPort: 2
but then fails:
CameraMaster::parseCSIPortMapInfo failed to read deserializer Tx port number from device tree, error No such file or directory
CameraMaster::parseCSIPortMapInfo setting default deserializer Tx port to : 4294967295
Driveworks exception thrown:
Bad access of safety result (underflow error)
Finally:
DW_FAILURE executing DW function:
dwSensorManager_initializeFromRig(…)
Device-tree investigation
The DriveWorks library references:
/deserializer/des_tx_port
/deserializer/des_i2c_port
/deserializer/cphy_rate_x2
/deserializer/cphy_rate_x4
/tegra/csi-port
The live P3960 device tree contains multiple sipl_devblk_* nodes. We found des_tx_port present only for two blocks:
sipl_devblk_0:
i2c-bus = 0
csi-port = 3
des_tx_port = 0
sipl_devblk_9:
i2c-bus = 9
csi-port = 2
des_tx_port = 1
while it is absent from:
  • sipl_devblk_1
  • sipl_devblk_3
  • sipl_devblk_7
  • sipl_devblk_12
For CSI-AB, DriveWorks reports:
  • but nevertheless fails to read des_tx_port.
Questions:
  1. Is this a known DRIVE OS 7.2.5 / P3960 DriveWorks device-tree issue?
  2. What is the expected sipl_devblk / des_tx_port configuration for MAX96724 on CSI-AB and CSI-GH?
  3. What changes to my rig file should i do to make my 3MP camera run on thor in 7.2.5?
    1. why does it work for driveOS 7.0.3 but fail for 7.2.5 ?
Dear @keshav.poygaipakkamkhanda ,
We have known issue with using camera with DW in DOS 7
2.5. I have shared patch library via private message. Could you please check and update?
I also reproduced the issue using NVIDIA’s DRIVE OS 7.2.5 sample_camera, not our application.
The patched libdw_sensors_std.so.7.2 is installed and verified by SHA256 and ldd.
I ran:
Shell
sudo /usr/local/driveworks/bin/sample_camera \
–rig=/opt/sw-constr/Configs/Rig/rig_3mp_csi_gh.json \
–offscreen=1
sample_camera successfully loads the OX03H10/MAX96724 CSI-GH rig and resolves:
Found matching DeviceBlock with csiPort: 11
but then fails:
Driveworks exception thrown: Bad access of safety result (underflow error)
NVIDIA sample_camera finally reports:
DW_FAILURE executing:
dwSAL_createSensor(…)
at CameraCustomSimpleApp.cpp:151
sample_camera_3mp_csi_gh_PATCHED.log (9.2 KB)
rig_3mp_csi_gh_json.txt (823 Bytes)
When nvsipl_camera succeeds on CSI-AB/link 0 (OX03H10-EXAE-BA0C_MAX96724_CPHY_x4) on DRIVE OS 7.2.5 (AGX Thor P3960) while DriveWorks camera.gmsl fails inside parseCSIPortMapInfo with a missing des_tx_port, the mismatch is in how libdw_sensors_std.so.7.2 translates legacy DriveWorks csi-port strings into Thor’s CPHY deserializer TX port map.
Why nvsipl_camera Works While camera.gmsl Fails
  • nvsipl_camera -c OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 loads the pre-bound platform configuration directly from the SIPL query database, which already populates desTxPort for MAX96724 on Thor P3960.
  • DriveWorks camera.gmsl builds its own NvSIPLCamera platform descriptor dynamically inside parseCSIPortMapInfo() from your --params string. On AGX Thor P3960 (libdw_sensors_std.so.7.2), passing only csi-port=ab (or interface=csi-ab) without explicitly binding the deserializer TX port or using the DriveWorks 7.2 SIPL config bridge leaves des_tx_port uninitialized.
Fix
In your DriveWorks camera.gmsl parameter string (or rig JSON parameter field), pass the explicit SIPL configuration name alongside the interface and link mask so parseCSIPortMapInfo inherits the MAX96724 CPHY port mapping directly:
camera-name=OX03H10-EXAE-BA0C_MAX96724_CPHY_x4,interface=csi-ab,link=0,output-format=processed,phy-mode=cphy
If your rig file uses raw sensor naming (camera-name=OX03H10), switching camera-name to the full SIPL platform entry (OX03H10-EXAE-BA0C_MAX96724_CPHY_x4) with phy-mode=cphy resolves the parseCSIPortMapInfo lookup failure on DRIVE OS 7.2.5.
I tested the suggested workaround with the provided patched libdw_sensors_std.so.7.2.
Test 1: full SIPL platform name
interface=csi-gh,
phy-mode=cphy,
link=0
This fails before SIPL initialization with:
DW_BUFFER_FULL:
The return string has insufficient capacity to hold the parsed param value
The sample_camera stack trace shows:
parseParam<32ul, 1024ul, 128ul>
suggesting the full platform-config value exceeds DriveWorks’ 32-character camera-name buffer.
Test 2: short camera name + phy-mode=cphy
interface=csi-gh,
phy-mode=cphy,
link=0
DriveWorks accepts this and generates:
but the original problem remains:
NVIDIA sample_camera subsequently fails directly in:
dwSAL_createSensor()
sample_camera_3mp_csi_gh_phymode.log (9.2 KB)
sensor_3mp_csi_gh_full_sipl.log (5.3 KB)
while nvsipl_camera -c OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 successfully streams the physical cameras.
Could you please confirm whether the patched libdw_sensors_std.so.7.2 requires an accompanying P3960 device-tree/DTBO patch, or provide the expected camera.gmsl parameter string for this OX03H10/MAX96724/CSI-GH configuration?
Could you let me know what parameters you used for the rig file ?
rig_3mp_csi_gh_full_sipl_json.txt (833 Bytes)
rig_3mp_csi_gh_phymode_json.txt (825 Bytes)
Looking at the two new logs you attached, that narrows the failure down to two specific boundaries inside libdw_sensors_std.so.7.2.
In Test 1, DW_BUFFER_FULL is thrown inside parseParam<32ul, 1024ul, 128ul> because the camera-name parameter parser uses a 32-byte fixed string buffer (dw::core::FixedString<32>, 31 characters max before the null terminator). Since OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 is 34 characters, it overflows that fixed buffer, whereas your Test 2 string (camera-name=OX03H10-EXAE-BA0C_MAX96724 at 26 characters with phy-mode=cphy) fits cleanly and expands internally to OX03H10-EXAE-BA0C_MAX96724_CPHY_x4.
In Test 2, the reason sample_camera gets past parameter parsing and matches DeviceBlock with csiPort: 11 but then fails with CameraMaster::parseCSIPortMapInfo failed to read deserializer Tx port number from device tree, error No such file or directory (defaulting to 4294967295 / 0xFFFFFFFF, which triggers the SafetyResult unsigned underflow exception) is that nvsipl_camera reads desTxPort from the compiled SIPL platform table in libnvsipl_devblk_ddi.so, whereas DriveWorks CameraMaster::parseCSIPortMapInfo() opens /proc/device-tree/ looking for the des_tx_port property under the CSI-GH (csiPort: 11) device-tree node.
You can check whether your patched libdw_sensors_std.so.7.2 accepts a rig parameter override or strictly reads /proc/device-tree by running:
strings -a /usr/local/driveworks/lib/libdw_sensors_std.so.7.2 | grep -E "device-tree|des_tx|tx_port|parseCSIPortMapInfo" -C 3
If parseCSIPortMapInfo in that build only queries the /proc/device-tree node without a params fallback key, then the patched library does need the matching P3960 DTB/DTBO overlay that populates des_tx_port = <0>; on the CSI-GH node so the kernel device-tree read returns 0 instead of ENOENT. Hope that helps get the rig streaming.
I checked the provided patched libdw_sensors_std.so.7.2 with:
strings -a /usr/local/driveworks/lib/libdw_sensors_std.so.7.2 | \
grep -Ei -C 5 ‘device-tree|des_tx|tx_port|deserializer Tx|parseCSIPortMapInfo’
The patched library still explicitly contains:
/proc/device-tree
sipl_devblk
/tegra/csi-port
/tegra/i2c-bus
/deserializer/dphy_rate_x
/pwr_ctrl/power_port
I do not see an apparent rig/parameter fallback for des_tx_port.
With the patched library, NVIDIA sample_camera and sensor_initializer both still fail in:
after successfully resolving:
The value falls back to:
followed by:
I also tested the proposed full SIPL name, but:
fails earlier with DW_BUFFER_FULL; the stack shows parseParam<32ul,...>, so the full platform configuration cannot fit in the current camera-name parser.
Could you please provide the matching P3960 DTB/DTBO patch for the supplied libdw_sensors_std.so.7.2, or confirm the exact des_tx_port node/value expected for the CSI-GH MAX96724 DeviceBlock? @cortex2 @SivaRamaKrishnaNV
Could you share nvsipl_camera command, log, syslog changes for the nvsipl_camera run.
Did you try with same rig file used in DOS 7.0.3?
Hi @SivaRamaKrishnaNV
In Drive OS 7.2.5,
Nvsipl Command:
sudo ./nvsipl_camera -c OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 --link-enable-masks ‘0x0000 0x0000 0x1000’ --disableISP0Output --disableISP1Output --disableISP2Output --enableRawOutput --showfps --runfor 10 -v4 2>&1 | tee ~/nvsipl_3mp_csi_gh.log
nvsipl_3mp_csi_gh.log (239.8 KB)
For DOS 7.0.3, this rig file worked.
rig_FWC_Cam_3MP_json.txt (1.3 KB)
This seems different to the one used in DOS 7.0.3. Did you use the same rig file in both DOS 7.0.3 and DOS 7.2.5? Please confirm.
Also, I have asked to share syslog corresponds to nvsipl_camera run on DOS 7.2.5 for further investigation
Apologies i uploaded the wrong rig file.
Below is the rig file that worked with DOS 7.0.3 on the thor.
rig_FWC_Cam_3MP_703_json.txt (1.3 KB)
Need this info to investigate further.
For the nvsipl command: (Drive OS 7.2.5)
sudo ./nvsipl_camera -c OX03H10-EXAE-BA0C_MAX96724_CPHY_x4 --link-enable-masks ‘0x0000 0x0000 0x1000’ --disableISP0Output --disableISP1Output --disableISP2Output --enableRawOutput --showfps --runfor 10 -v4 2>&1 | tee ~/nvsipl_3mp_csi_gh_v4.log
Here are the system logs that i could capture.
dmesg_3mp_csi_gh_camera.log (828 Bytes)
dmesg_3mp_csi_gh_full.log (2.2 KB)
could you please share /var/log/syslog for the application run?
Here are the sys logs for sample_camera and sensor intializer.
dmesg_3mp_csi_gh_link0.log (17.5 KB)
sample_camera_3mp_csi_gh_link0.log (9.2 KB)
sensor_initializer_3mp_csi_gh_link0.log (8.2 KB)
rig_3mp_csi_gh_link0_json.txt (823 Bytes)
syslog_s.zip (33.5 MB)
Additional info on the camera drivers:
$ strings /usr/lib/nvsipl_drv/libnvsipl_qry_ox03h10_max96724.so | grep -E ‘OX03H10.*MAX96724|OX03H10.*CPHY’ | sort -u
“description”: “OX03H10-EXAE-BA0C module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C module in 4 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_2LANE module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_2LANE module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_2LANE module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_2LANE module in 4 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_F module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_F module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_F module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_F module in 4 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_H module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_H module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_H module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_H module in 4 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_M module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_M module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_M module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_M module in 4 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_R module in 2 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_R module in 2 lane CPHY, TPG mode”,
“description”: “OX03H10-EXAE-BA0C_R module in 4 lane CPHY mode”,
“description”: “OX03H10-EXAE-BA0C_R module in 4 lane CPHY, TPG mode”,
“name”: “OX03H10-EXAE-BA0C_2LANE_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_2LANE_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_2LANE_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_2LANE_MAX96724_CPHY_x4_TPG”,
“name”: “OX03H10-EXAE-BA0C_F_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_F_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_F_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_F_MAX96724_CPHY_x4_TPG”,
“name”: “OX03H10-EXAE-BA0C_H_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_H_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_H_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_H_MAX96724_CPHY_x4_TPG”,
“name”: “OX03H10-EXAE-BA0C_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_MAX96724_CPHY_x4_TPG”,
“name”: “OX03H10-EXAE-BA0C_M_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_M_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_M_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_M_MAX96724_CPHY_x4_TPG”,
“name”: “OX03H10-EXAE-BA0C_R_MAX96724_CPHY_x2”,
“name”: “OX03H10-EXAE-BA0C_R_MAX96724_CPHY_x2_TPG”,
“name”: “OX03H10-EXAE-BA0C_R_MAX96724_CPHY_x4”,
“name”: “OX03H10-EXAE-BA0C_R_MAX96724_CPHY_x4_TPG”,
I need syslog when nvispl_camera is run. That log will give hints about params to use for sample_camera. It should have entry like below in log.
2026-04-28T05:21:35.272038+00:00 tegra-ubuntu nvsipl_camera: [TS:634189358359] Module_id 30 Severity 5 : ---------- START PLATFORM CONFIGURATION ----------
2026-04-28T05:21:35.272138+00:00 tegra-ubuntu nvsipl_camera: [TS:634189419350] Module_id 30 Severity 5 : platform:
2026-04-28T05:21:35.272183+00:00 tegra-ubuntu nvsipl_camera: [TS:634189422387] Module_id 30 Severity 5 : platformConfig
Also
has "parameter": "camera-name=OX03H10-EXAE-BA0C_R1E_H,deserializer=MAX96712_Fusa_nv,disable-custintf=1,groupInit=1,interface=csi-ef,CPHY-mode=1,link=2,output-format=processed,skip-eeprom=1,async-record=1,file-buffer-size=16777216",
Where as
has
camera:front:rooftop:left in parameter string: camera-name=OX03H10-EXAE-BA0C_MAX96724,interface=csi-gh,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1,nito-file=/usr/share/camera/OX03H10-EXAE-BA0C.nito
which seems to have different camera name used. Are you using same camera module?
I will provide /var/log/syslog captured during the successful nvsipl_camera run on DRIVE OS 7.2.5.
syslogs.zip (17.3 MB)
Regarding your question on the different camera names in the rig files, I have used the same camera module across DOS 7.0.3 testing and DOS 7.2.5 testing.
the rig_FWC_Cam_3MP_703 file was our previous DRIVE OS 7.0.3 configuration. That setup used:
camera-name=OX03H10-EXAE-BA0C_R1E_H,deserializer=MAX96712_Fusa_nv,interface=csi-ef,link=2
This works on the Thor and we were using the deser 96712.
The current DRIVE OS 7.2.5 test is for our OX03H10 3 MP camera connected through MAX96724 on CSI-GH. The NvSIPL platform configuration that successfully streams this camera is:
with:
--link-enable-masks '0x0000 0x0000 0x1000'
We had to migrate to DOS 7.2.5 to interface with deser 96724 and now i am experimenting with the rig file names to see which works with the camera attached to csi-gh, link=0\1\2\3.
If you recommend any changes to be made in the rig file and try out the camera sample, i can do the same and provide the logs
So with below config is it working on DOS 7.2.5 when camera is connected to CSI-EF?
Could you please try parameter": "camera-name=OX03H10-EXAE-BA0C,disable-custintf=1,disable-auth=1,interface=csi-gh,skip-eeprom=1,CPHY-mode=1,link=0,fifo-size=8,output-format=raw+processed,async-record=1,deserializer=MAX96724_Fusa_nv,file-buffer-size=16777216,format=mp4", for CSI-GH
Thanks. I tried the parameter string you suggested on DRIVE OS 7.2.5 using the single OX03H10 camera on CSI-GH.
I tested it with both sample_camera and sensor_initializer.
The parameter used was:
Both applications fail at the same point. DriveWorks reports:
devBlock: 0 Passive = 0 Interface = csi-gh Camera_name = OX03H10-EXAE-BA0C_CPHY_x4 Link = 0 GroupInit = 0 RecCfg = 0
followed by:
CameraMaster:GetPlatformCfg: Failed to query platform cfg for camera: OX03H10-EXAE-BA0C_CPHY_x4
Therefore, with the suggested parameters, DriveWorks still appears to query the platform configuration as:
whereas the successful NvSIPL run reports:
platformConfig: OX03H10-EXAE-BA0C_MAX96724_CPHY_x4
The NvSIPL platform dump also reports:
CameraModuleInfo name: OX03H10-EXAE-BA0C
Deserializer: MAX96724_Fusa_nv
Serializer: MAX96717F
csiPort: 11
linkIndex: 3
Regarding the CSI-EF question, the OX03H10-EXAE-BA0C_R1E_H / MAX96712_Fusa_nv / csi-ef / link=2 configuration was our previous DRIVE OS 7.0.3 setup. Omnivision didnt not provide drivers for DOS 7.2.5 that are compatible with deser 96712. So we cannot test the same camera in CSI-EF interface.
I also tested one additional variation based on the NvSIPL platform configuration. I changed the camera name from:
to:
while retaining:
This makes a significant difference.
With camera-name=OX03H10-EXAE-BA0C, DriveWorks constructs:
and fails with:
With camera-name=OX03H10-EXAE-BA0C_MAX96724, DriveWorks instead constructs:
and successfully finds the platform configuration:
Found matching DeviceBlock with csiPort: 11 for camera: OX03H10-EXAE-BA0C_MAX96724_CPHY_x4
It then proceeds further but fails at:
followed by:
The same behavior occurs with both sample_camera and sensor_initializer.
One point that may be relevant is that the successful NvSIPL /var/log/syslog platform dump reports:
csiPort: 11
desTxPort: 4294967295
Despite this value, NvSIPL successfully initializes the camera and VI reports:
VI capture setup complete (channel_id=0, csi_stream=5, vc=3)
Therefore, the platform selection now appears correct in DriveWorks, but DriveWorks still fails after attempting to obtain the deserializer Tx port information.
