Driver 340.102 fails to build for kernel 4.11.3
The driver needs to be patched in order for the module to be built on 4.11 and newer kernels.
See
https://pkgs.rpmfusion.org/cgit/nonfree/nvidia-340xx-kmod.git/tree/4.11_kernel.patch
for a patch.
I’m willing to go out on a limb and suggest that given their release dates, the drivers for the older releases need to be patched as well.
bump
With the patch you provided,I am unable to comply a new installation package,follow is their output:
patching file ./kernel/nv-drm.c
Hunk #1 succeeded at 22 with fuzz 1.
Hunk #3 FAILED at 66.
1 out of 3 hunks FAILED – saving rejects to file ./kernel/nv-drm.c.rej
can’t find file to patch at input line 222
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
Are you aware that there are three patches required for 4.11 for 340.102 driver
+ tar --use-compress-program xz -xf /usr/share/nvidia-340xx-kmod-340.102/nvidia-340xx-kmod-340.102-i686.tar.xz
+ echo 'Patch #0 (nv-linux-arm.patch):'
+ /usr/bin/patch --no-backup-if-mismatch -p1 --fuzz=0
patching file kernel/nv-linux.h
Patch #1 (4.9.0_kernel.patch):
+ echo 'Patch #1 (4.9.0_kernel.patch):'
patching file kernel/nv-drm.c
Patch #2 (4.10.0_kernel.patch):
+ echo 'Patch #2 (4.10.0_kernel.patch):'
Hunk #1 succeeded at 2083 (offset 1 line).
Hunk #2 succeeded at 2132 (offset 1 line).
patching file kernel/nv-pat.c
patching file kernel/uvm/nvidia_uvm_lite.c
Patch #3 (4.11_kernel.patch):
+ echo 'Patch #3 (4.11_kernel.patch):'
patching file kernel/uvm/nvidia_uvm_linux.h
+ exit 0
My Driver installation file has been patch for kernel-4.10,so it isn’t the case i think.
I think we are talking different things.You mean patch for nvidia-340xx-kmod-340.102, but i mean driver installation file itself.
It’s the same code
Another patch has been applied for my installation file successfully.
Here is the url of the topic,https://devtalk.nvidia.com/default/topic/1005209/linux/fully-working-patch-for-nvidia-driver-340-102-compiler-installer-file-and-linux-kernel-4-11/
@leigh123linux
Please accept my apologizes, but how do I apply those patches 4.9 and 4.10?
I am not familiar with patch code and I do not know how to apply it. It looks to me that 4.09 code is like “git text” and not the code to patch something.
I do not use kernel 4.11. I use Ubuntu Linux 16.04, kernel 4.10.0.33
Thank you advance.
