This happens a few minutes after I started playing minecraft. The game froze and crashed by a segmentation error in gl driver with following log in terminal:
https://gist.github.com/cthbleachbit/451e1f4911e37bbda69f4d425451fe1a
Thanks for reporting this issue. Can you attach gdb to the game process and share backtrace showing seg fault is in gl lib/driver? What desktop environment you are running - KDE, GNOME, XFCE or else? Are the desktop effects enabled? How long need to play this game to trigger this issue? Is the issue reproduce on specific map in game? Is there any custom setting done in Game and OS? What version of minecraft you are running ? What if you are running JAVA what is its version? Please attach nvidia bug report to your existing post as soon as issue hit. Can you share video recording showing this issue? Are there any old nvidia drivers where you have not seen this issue?
