Power usage and cap is N/A for Titan XP Collectors with driver 390.48 and trying to adjust power limit
with nvidia-smi -i 1 -pl 300 results in error
“Changing power management limit is not supported for GPU: 00000000:06:00.0” .
This used to work under an older driver 390.25 and earlier. Also I have set up Powermizer and overclocking GPU and Mem frequency works fine with nvidia settings. Raising the power limits for the 1080ti’s also works fine with nvidia-smi as you can see below.
Is this a known issue, is this going to be fixed soon, are there any workarounds ?
thanks.
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 GeForce GTX 108… On | 00000000:05:00.0 On | N/A |
| 23% 34C P0 62W / 300W | 406MiB / 11175MiB | 0% Default |
| 1 TITAN Xp COLLEC… On | 00000000:06:00.0 Off | N/A |
| 23% 31C P0 N/A / N/A | 416MiB / 12196MiB | 0% Default |
| 2 GeForce GTX 108… On | 00000000:09:00.0 Off | N/A |
| 23% 33C P0 61W / 300W | 410MiB / 11178MiB | 0% Default |
